Looking for a dial caliper
« back to Hand Tools forum
Forum topic by bbc557ci posted 03-21-2014 09:19 PM 1422 views 0 times favorited 25 replies Add to Favorites Watch
View bbc557ci's profile
bbc557ci
595 posts in 2194 days
03-21-2014 09:19 PM
Hey all….I’ve been looking for a dial caliper. I checked out a few at Harbor Freight and wasn’t able to get any of them to set to zero. So I passed on them.
Don’t want to break the bank just looking for something decent. Any suggestions where to look on line?
Suggestions appreciated :o)
Thanks !!
-- Bill, central NY...no where near the "big apple"
25 replies so far
View Fred Hargis's profile (online now)
5071 posts in 2613 days
#1 posted 03-21-2014 09:29 PM
I’ve had this fractional dial from Highland Hardware for 10 years or so, and it’s done well. For woodworking, the fractional scale is quite handy. Always returns to “0”, and it measures accurately when compared to my digital caliper (Mitutoyo)
bbc557ci
#2 posted 03-21-2014 09:38 PM
Fred – maybe I’m using the wrong terminology/description. I’m looking of the type used to set the fence on a table saw. To line the fence up with the blade. The type I’m looking for has a spring loaded end that changes the reading when pushed on. I’ll try and dig up a photo and post it here. But thanks!!
bbc557ci
#3 posted 03-21-2014 09:42 PM
Here we go…looking for something like what’s in the link
http://syracuse.craigslist.org/tla/
View changeoffocus's profile
changeoffocus
467 posts in 1737 days
#4 posted 03-21-2014 09:42 PM
Sounds like you are looking for a dial indicator.
View Bigriverman's profile
Bigriverman
15 posts in 1766 days
#5 posted 03-21-2014 09:42 PM
The right word you’re looking for is indicator, not caliper.
bbc557ci
#6 posted 03-21-2014 09:44 PM
Ah!! I stand corrected. Thank you both. Would help if I used the right description (palm hits forehead)
View Ocelot's profile
Ocelot
2029 posts in 2758 days
#7 posted 03-21-2014 09:48 PM
Harbor Freight’s dial indicators are cheap and adequate.
View TheDane's profile
TheDane
5516 posts in 3783 days
#8 posted 03-21-2014 09:50 PM
On dial indicators, zero is relative … you set the indicator up in a jig or bracket, put the leg against the surface you are calibrating, then set the twist dial to zero.
I have had a Harbor Freight dial indicator for years … very happy with it.
bbc557ci
#9 posted 03-21-2014 09:59 PM
TheDane – I never used one before so didn’t know that, but it makes perfect sense.
So, guess I’ll take another trip back to HF this weekend…...
Thanks TheDane for the explanation.
View steve_in_ohio's profile
steve_in_ohio
1195 posts in 1730 days
#10 posted 03-21-2014 10:55 PM
You can set the dial indicator to zero if it doesn’t read zero when not pressed
-- steve, simple and effective woodworking---etsy.com/shop/SussmanWoodworking--
View rg33's profile
rg33
83 posts in 2122 days
#11 posted 03-22-2014 12:15 AM
Bbc557, I think I know why you are confused with the setting to zero on the harbor freight dial indicators. As others have noted, zero is relative. When you are ready to measure your offset, make sure you compress the indicator at least a little bit (.050” or so, or for aligning your fence I’d shoot for halfway say 1/2” on the 1” travel indicator so you have plenty of travel both ways) then, you turn the bezel to zero and this becomes your baseline. All dial indicators will have a lockscrew, so make sure to loosen it otherwise you’ll have a hard time turning the bezel (that may be the reason why you thought you couldnt get it to zero). Also the bezel on my HF indicator will sometimes stick a little bit if its sat there for a while but a little extra force always gets it moving again.
Along with my 6” digital calipers, and clamps, this is one of my best buys at harbor “Fright”
View woodchuckerNJ's profile
woodchuckerNJ
1288 posts in 1754 days
#12 posted 03-22-2014 01:50 AM
How could you not get it to set to zero????
The dial rotates, set it to zero.
I have a HF fractional dial, and it is absolutely dead on.
The only disadvantage to it is the fractional is in the inner dial, while .01 is outer .
The Highland looks good as it has the dials reversed, but they are using Igaging now, and I read some reviews that make me wonder.
and to the others, he said caliper, not dial indicator..
damn… reading down, I see he wants a dial indicator..
The HF dial indicators are great tools for the price. Very accurate. I have feeler gauges and setup blocks. They are dead on.
-- Jeff NJ
View Woodknack's profile
Woodknack
12338 posts in 2500 days
#13 posted 03-22-2014 07:13 AM
Bought mine from Little Machine Shop, I highly recommend them—fast and very reasonable shipping.
http://littlemachineshop.com/products/product_view.php?ProductID=1236&category=
#14 posted 03-22-2014 11:57 AM
Back to the HF dial indicator then, it doesn’t matter if you can set it to “0” (oooops, I see several others noted that). What you are interested in is that the reading (whatever it is) is the same on both ends of the blade (or Masterplate). BTW, you align the blade to the miter slots, and then the fence to those miter slots as well…it’s a lot easier plus it means the miter gauge will work as intended.
bbc557ci
#15 posted 03-22-2014 03:25 PM
Sorry for the confusion on what I was actually looking for….my bad fellas!! I’m sure the HF indicator will do the job.
Fred, I think the blade and miter slots are lined up pretty well. That was one of the 1st things I checked after dragging the ol’ Unisaw home. But a dial indicator will come in handy to confirm/double check the alignment, and correct it if necessary. Also, I had the fence lined up pretty much dead on with the miter slots, but I set the back side of the fence maybe 1/64th (or less) farther away from the blade. Rips are very smooth with minimal to zero blade marks.
Thanks again everyone for the info and helpful hints!!
