4" vs 6" dust collection
Forum topic by jimmy J posted 03-21-2014 12:21 PM 1240 views 0 times favorited 6 replies Add to Favorites Watch
View jimmy J's profile
jimmy J
229 posts in 2312 days
03-21-2014 12:21 PM
I need to rerun much of the duct tubing in my shop. It is all 4” today, but was thinking of making some of the new main trunk at 6”. However, the main trunk will not be able to run all the way back to the vacuum at 6”. Ie, after the 4” connections from the shop machines, there will be about 20” of 6” trunk tubing before it will have to down convert to 4” to navigate the last 20” to the vacuum). Do you all think this makes sense to do, or just go with all 4”? the vaccume i am using is the HF unit.
View DIYaholic's profile
19580 posts in 2608 days
#1 posted 03-21-2014 12:28 PM
Only switching out the “middle” of the runs to 6” won’t improve performance. I wouldn’t waste my time with that non-upgrade.
View gtbuzz's profile
427 posts in 2374 days
#2 posted 03-21-2014 12:30 PM
Won’t do a thing. I’m also not sure the HF is capable of supporting 6” runs. I’d leave everything as-is.
Shawn Masterson
1324 posts in 1881 days
#3 posted 03-21-2014 03:32 PM
you’ve got to have serious power for 6” lines. anything under 3hp and a 14” impeller really needs 4” to perform its best.
4908 posts in 2426 days
#4 posted 03-21-2014 03:52 PM
+1 for the waste of time/effort/money.
View crank49's profile
4030 posts in 2904 days
#5 posted 03-21-2014 05:42 PM
The 6” section will fill up with dust over time to equal the size of the 4” connected to it. Don’t do it. The HF will work fine with a 5” pipe, or a 4” and a 3” connected at the same time.
A 4” reduces the volume somewhat, but not too bad with a short run.
A 6” reduces the velocity somewhat, but would help a long run.
Don’t run 6” pipe vertical with the HF as you may have drop-out.
edit. For what it’s worth, I add that a pair of 4” pipes would have about the same characteristics as a single 6”.
jimmy J
#6 posted 03-28-2014 05:08 PM
thanks all
