How to drill a 3/64" hole?
Forum topic by HarveyDunn posted 03-20-2014 09:42 PM 1413 views 0 times favorited 23 replies Add to Favorites Watch
View HarveyDunn's profile
HarveyDunn
328 posts in 1879 days
03-20-2014 09:42 PM
I need some 3/64” holes – could go “all the way up to” 1/16” if I had to.
I don’t have a drill press. I do have a cordless drill plus the original cordless drill – a Millers Falls egg beater.
How on earth do I chuck up something that small?
23 replies so far
View TravisH's profile
TravisH
615 posts in 2083 days
#1 posted 03-20-2014 09:50 PM
If you can’t chuck it as is then add a Dremel collet.
View TheDane's profile
TheDane
5524 posts in 3811 days
#2 posted 03-20-2014 09:50 PM
Harvey—Do you have a Dremel? I use my Dremel to drill tiny holes for scroll saw blades.
View dirtycurty's profile
dirtycurty
44 posts in 1726 days
#3 posted 03-20-2014 09:53 PM
View WayneC's profile (online now)
WayneC
13775 posts in 4245 days
#4 posted 03-20-2014 09:59 PM
Yankee Brace. LOL
HarveyDunn
#5 posted 03-20-2014 10:06 PM
Don’t have a Dremel, but are you saying but the bit in a Dremel collet then put the Dremel collet in my regular drill?
Wayne, I have no idea what I’m looking at in that photo!
View bigblockyeti's profile
bigblockyeti
5229 posts in 1869 days
#6 posted 03-20-2014 10:07 PM
A cordless drill should be up to the job, I’d be careful as I’ve broken more than my share of small diameter drill bits using a hand held drill. If you’re having trouble with the chuck jaws engaging the drill shank, you could wrap a small bit of tape around the shank. The precision with which the hole can be drilled will be somewhat compromised, as will how much torque and force you can apply.
WayneC
#7 posted 03-20-2014 10:08 PM
It is a bit brace. I was trying to be funny. :)
WayneC
#8 posted 03-20-2014 10:15 PM
A dremel is a good suggestion or you could use something like this…
http://www.amazon.com/Neiko-4-Inch-Keyless-Chuck-Conversion/dp/B007TCHKXW/ref=pd_sim_hi_7?ie=UTF8&refRID=15CBNR3S90ZEEJ3H5RJS
View crank49's profile
crank49
4032 posts in 3119 days
#9 posted 03-20-2014 10:32 PM
Very tiny bits need a lot of speed.
The Dremel is a good choice for this type drilling.
So would a Foredom be good, but much more spendy.
If you do try it with a regular drill use the highest speed you have, and a very light touch.
View dhazelton's profile
dhazelton
2789 posts in 2445 days
#10 posted 03-20-2014 10:47 PM
How small is the smallest InstyBit countersink? Maybe you could chuck your bit in that holder.
117238 posts in 3725 days
#11 posted 03-20-2014 10:57 PM
If you have a 23 gauge nail gun lower the air presser and shoot a 22 gauge nail were you want the hole and then pull the nail out.You will have to experiment with the air presser to get it just right so you don’t sink the 22 gaugenail to deep, practice on a scrap because 22 gauge nails break easily .
View changeoffocus's profile
changeoffocus
467 posts in 1765 days
#12 posted 03-20-2014 11:13 PM
Several places sell small bit sizes with a 1/4” shank like the driver bits. Welding shops sell tip cleaning drills with similar enlarged shanks for cleaning cutting torches.
View Whiskers's profile
Whiskers
389 posts in 2175 days
#13 posted 03-21-2014 02:05 AM
I actually had the opposite problem with tiny drill bits in that I do have a drill press, but it’s chuck is huge so grabbing tiny bits straight is problematic. Lee Valley to the rescue with one of their little toys. Every so often they put little pair of chucks on sale. They are not expensive at all. One end is 1/4” shank so will fit in any drill or drill press. Attached to that shank is a little chuck that does a excellent job with the small bits.
View Lewis Landry's profile
Lewis Landry
13 posts in 1761 days
#14 posted 03-21-2014 02:07 AM
1/32” drill bit shown
WayneC
#15 posted 03-21-2014 02:09 AM
Whiskers, I looked for the LV chucks earlier and did not see them. Do you know if they still carry them?
