Is 1/2" Baltic Birch Pl Strong Enough??
Forum topic by titanxt posted 03-19-2014 03:27 PM 1119 views 0 times favorited 16 replies Add to Favorites Watch
View titanxt's profile
titanxt
30 posts in 1726 days
03-19-2014 03:27 PM
I am building some boxes that are 30”x30” and about 24” deep that will hold two 4” drawers and two 10”drawers. The boxes will serve as a bank of drawers under my 2×4 framed reloading bench. Some of the larger drawers might have to hold some bullets, but I cannot see loading them full of heavy bullets since I have so many other pieces of reloading gear to house. With that having been said, I am trying to decide where I need to use 3/4” BB and where to use the less expensive 1/2” BB? What do you think?
Thank you!
Andy
-- www.creeativewoodworking.com
16 replies so far
View jumbojack's profile
jumbojack
1676 posts in 2618 days
#1 posted 03-19-2014 03:44 PM
trouble with 1/2 ply for cases is there is not much to screw to. Traditionally cases are 3/4. Drawers for sure can be 1/2. Will you be using hardware drawer slides or ?
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2364 days
#2 posted 03-19-2014 03:45 PM
I think that, provided you use solid joinery (dados, rabbets, pocket screws, etc), the 1/2” should be fine. It sounds like they’re relatively small, won’t get moved around or abused, and won’t hold much weight. One thing to consider is that 1/2” does not leave much depth for the screws that mount the drawer slides, and limits the depth of the joinery. I’d probably use 3/4” for those reasons, and save the 1/2” for the drawers.
Edit : Looks like Jack and I posted at the same time…so yeah…what Jack said.
jumbojack
#3 posted 03-19-2014 03:48 PM
man I just went to your page that sword case is AWESOME!
titanxt
#4 posted 03-19-2014 03:59 PM
Thank you Jack!! That project took me quite a while and I sweated over it quite a bit because it was for a good friend of mine son.
3/4” for the carcass is a good plan – I will do that. So, 1/2” for all of the drawer parts including the bottom will be strong enough for most items short of a drawer full of bullets?
Thank you!
Andy
View Redoak49's profile
Redoak49
3239 posts in 1983 days
#5 posted 03-19-2014 04:01 PM
I would use 3/4” plywood or BB for the drawers. The 1/2” thick material is IMO difficult to make strong joints as there is just not enough material. I would be a shame to build with 1/2” material and then find the drawers are not strong enough.
As mentioned, it will also make a difference if you are using drawer slides or not. If no slides then you can put a lot of pressure on the drawers pulling them out and pushing them in.
titanxt
#6 posted 03-19-2014 04:03 PM
I will be using metal slides for sure.
Thank you!
Andy
BinghamtonEd
#7 posted 03-19-2014 04:05 PM
Is it a full single 30 (well, more like 28) inch-wide drawer?
View MT_Stringer's profile
MT_Stringer
3168 posts in 3225 days
#8 posted 03-19-2014 04:28 PM
I vote for 3/4 inch sides, face frame front and 1/2 inch back. That should make a rock solid cabinet. The big box stores sell Birch or Maple. Put the good side facing outward and you should be good to go.
100# full extension drawer slides should work great. Soft close is a plus if you so desire.
1/2 inch for the drawers should be fine.
Good luck.
Mike
titanxt
#9 posted 03-19-2014 04:28 PM
Yes. 28” would be correct.
Andy
BinghamtonEd
#10 posted 03-19-2014 04:33 PM
I think 1/2” would be fine for the drawers, but if you’re concerned about sagging, you could add re-enforcement to the bottom, or make the bottom out of 3/4”.
View waho6o9's profile
waho6o9
8187 posts in 2571 days
#11 posted 03-19-2014 04:44 PM
I’d use 3/4 BB as well.
View bigblockyeti's profile
bigblockyeti
5111 posts in 1715 days
#12 posted 03-19-2014 05:04 PM
I would have to agree with some of the above posts, 1/2” should be plenty, but attention will have to be given to the jointery, the stronger the better!
titanxt
#13 posted 03-19-2014 05:22 PM
On the deep drawers (10”), I will probably do a 1/2” dado. For the smaller, 4” drawers I will probably do a 1/4” rabbet into a 1/4” dado. Sound reasonable?
Andy
BinghamtonEd
#14 posted 03-19-2014 06:21 PM
If you’re already cutting the 1/2” dado for the deep drawers, might as well just do them all that way. One setup for all the drawers. What does the 1/4” rabbet get you, besides less rigidity?
titanxt
#15 posted 03-19-2014 06:24 PM
A whole 1/4” more of drawer depth!..... Valid point.
Andy
