How to secure loose knots prior to machining.
Forum topic by dbhost posted 03-19-2014 02:27 PM 876 views 0 times favorited 6 replies Add to Favorites Watch
View dbhost's profile
dbhost
5686 posts in 3105 days
03-19-2014 02:27 PM
I have some walnut I want to use for the mission dog kennel project that has been in my shop for a couple of years now. The problem I have is loose knots, and cracks / bark inclusions in the stock.
I was wondering, how could I secure that? I seem to remember a video from Marc Spagnulo on filling the voids with 2 part epoxy mixed with sawdust from the stock in question, and mind you. generating walnut sawdust won’t be a problem at all. Keeping it controlled IS…
So how would I go about doing this? Would any old epoxy work or do I need some special kind?
-- My workshop blog can be found at http://daves-workshop.blogspot.com, YouTube Channel https://www.youtube.com/channel/UCoa-AgyeFWqnQfGIJwdzkog
View woodshopmike's profile
woodshopmike
225 posts in 1537 days
#1 posted 03-19-2014 02:44 PM
Hey Dave,
I usually use the 5 min loctite epoxy that you can pick up almost anywhere.
For gathering dust I use an oscillating spindle/belt sander with the vacuum off. I hold the wood to sand in my right hand while holding a piece of cardboard (some use a cup) in my left hand which acts as a wall to keep the dust from going everywhere. Once you get a little pile I put the dust in either a small jar or bag.
Also worth noting is to clean off the surface of your sander before you begin. This way you only collect the target species and not maple, cedar, walnut dust.
-- www.woodshopmike.com, www.woodshopmikestudio.etsy.com
View DocSavage45's profile
DocSavage45
8430 posts in 2716 days
#2 posted 03-19-2014 05:56 PM
Sounds right! Run a test on a small practice piece. Dust not coarse particles. I used coarse particles and it failed. One trial learning? Oh yeah and remembering.
I believe Marc is an LJ member. maybe a pm to him?
-- Cau Haus Designs, Thomas J. Tieffenbacher
View jdh122's profile
jdh122
969 posts in 2691 days
#3 posted 03-19-2014 06:22 PM
I’f you have any knots that are super loose you could pop them out and simply glue them back in with yellow glue. For the cracks, on the other hand, epoxy plus sawdust should work fine.
-- Jeremy, in the Acadian forests
dbhost
#4 posted 03-20-2014 01:01 AM
Too much gap on the loose knots for yellow glue. Would need something to fill the void. That is why I was thinking epoxy…
View Roger's profile
Roger
20898 posts in 2677 days
#5 posted 03-22-2014 12:08 AM
Either epoxy and sawdust, or for walnut I’ve seen lead shavings from a pencil lead with epoxy does pretty good on Walnut. I would experiment on a piece of scrap first. That’s just me.
View TechTeacher04's profile
TechTeacher04
362 posts in 1405 days
#6 posted 03-22-2014 12:16 AM
You could also knock them out and use dutchman where needed. I like the look of them and they will add structural integrity. I prefer the looks of the bowtie pattern dutchman.
