G0490X jointer info needed.
Forum topic by Shawn Masterson posted 03-18-2014 10:19 PM 733 views 0 times favorited 5 replies Add to Favorites Watch
Shawn Masterson
1324 posts in 1853 days
03-18-2014 10:19 PM
Topic tags/keywords: lathe planer scroll saw bandsaw biscuit joiner drill press router miter saw jointer plane grizzly
I recently picked up a Grizzly 1018 jointer. It needs bearings and belts. The belts are skinny v-belts. I was thinking of ordering a set of pulleys and belt from a G0490x. I figured going to a serpentine belt would be way better than the 2 skinny v-belts. I checked grizzly’s website and all the specs say is pulley. There is no info aside from pulley, so I called and the tech was no help.
I am looking for any specs you guy can help with. Mostly shaft sizes on the cutter head and motor, also belt length, and pulley diameter.
I tried to get this stuff from grizzly and they had no clue.
Thanks for the help.
5 replies so far
Shawn Masterson
#1 posted 03-20-2014 07:27 PM
bump
View bowedcurly's profile
bowedcurly
519 posts in 1633 days
#2 posted 03-21-2014 01:00 AM
just take the bearings off and go to a induatrial supply store and pick some up, just get a good brand,Timken is a good brand, Ereplacement parts should have these along with a exploded view
-- Staining killed the wood<<<<<>>>>>Dyeing gave it life
bowedcurly
#3 posted 03-21-2014 01:01 AM
Grizzly PDF
View pintodeluxe's profile
pintodeluxe
5566 posts in 2717 days
#4 posted 03-21-2014 01:49 AM
I would stick with the factory belts. Are you sure a 490 belt would even fit?
Shawn Masterson
#5 posted 03-21-2014 11:38 AM
with 2 new pulleys of the right size yes
