gluing butt joints
« back to Joinery forum
Forum topic by dfox52 posted 03-18-2014 07:03 PM 1203 views 0 times favorited 12 replies Add to Favorites Watch
View dfox52's profile
dfox52
27 posts in 1722 days
03-18-2014 07:03 PM
What would be the best way to butt join some short lengths of pine I have laying around? I have this idea to use up my short lengths of scrap to make small tops for painted items like end tables. I was thinking of using a biscuit joiner but am wondering if the grain in the biscuits might be less than ideal for gluing end-to-end. Should I use dowels instead? The butt joints will get some reinforcement from long grain on adjacent boards (picture staggered joints like a hardwood floor) so I’m thinking that the biscuits will suffice. What do you think?
12 replies so far
View chrisstef's profile
chrisstef
17429 posts in 3035 days
#1 posted 03-18-2014 07:39 PM
IMO if youre going to have staggered joints on either side there’s no need for anything at the butt joints. The long grain glue joints would be plenty strong to hold it all together. If you were worried about the butt joints you could half lap them together. That would give you the most glue surface. You could also use pockets screws.
View crank49's profile
crank49
4032 posts in 3000 days
#2 posted 03-18-2014 07:52 PM
Half laps would be great for strength and I think you need that to keep the finish (paint) from cracking over time at the butt joint.
dfox52
#3 posted 03-18-2014 08:28 PM
Half lap sounds good! Never thought of that. Ya, I figured the adjacent boards would hold it all together but as crank said, I would be afraid that the butt seams would let go later on and crack.
View Woodknack's profile
Woodknack
11827 posts in 2409 days
#4 posted 03-18-2014 08:39 PM
Scarf joint would be the the next easiest but butt joints would be fine since they will be staggered. Wood shrinks very little along the grain.
View ToddJB's profile
ToddJB
7991 posts in 2159 days
#5 posted 03-18-2014 08:43 PM
dfox, good question, I was wondering this myself – I’m considering doing this for an outfeed/general purpose table.
-- I came - I sawed - I over-built
View MT_Stringer's profile
MT_Stringer
3172 posts in 3260 days
#6 posted 03-18-2014 09:01 PM
Are all of your short pieces the same thickness? That would help. Or, plane them until they are the same thickness. Your job would go alot easier.
Then cut the half laps.
Woodknack
#7 posted 03-18-2014 09:10 PM
With half laps you will have 2 smaller butt joints but still butt joints.
Shawn Masterson
1325 posts in 1977 days
#8 posted 03-18-2014 09:55 PM
Really this is the only way to go for a strong end grain joint
http://www.ebay.com/itm/like/131053304290?lpid=82
View NiteWalker's profile
NiteWalker
2737 posts in 2605 days
#9 posted 03-18-2014 10:03 PM
Half laps would be great. While it’s still a butt joint, you have the additional strength of the face grain glue surfaces of the laps.
dfox52
#10 posted 03-19-2014 09:13 AM
Rick, the glue strength in the half lap comes from creating two long grain faces. The two “half” thickness butts created from the joint contribute little to nothing in terms of holding the two pieces together.
dfox52
#11 posted 03-19-2014 09:17 AM
My last comment posted twice. There was no delete option so I edited it with this text.
Woodknack
#12 posted 03-19-2014 06:15 PM
My understanding of the OP was the concern of butt joints showing up under paint, not really strength because they sandwiched between other boards so where are they going to go. Butt joints would probably be okay but it’s a valid concern because getting end grain butt joints perfect can be tricky. I agree that half laps would minimize the problem but you are still left with 2 small butt joints that you have to get perfect. In a commercial piece they would be finger jointed like Shawn suggested. I suggested scarf joints because they are strong, quicker than half laps, and eliminate the straight lines.
