Band saw wander
Forum topic by Farrout posted 03-18-2014 12:22 PM 1698 views 0 times favorited 11 replies Add to Favorites Watch
View Farrout's profile
Farrout
185 posts in 3208 days
03-18-2014 12:22 PM
I have a small Craftsman 10” band saw. Admittedly not expensive but it’s all I have room for.
The blade will constantly wander to the right when I’m cutting.
I’ve changed the blade, tried different tension settings, checked the guide bearings but no help.
Any advice on doing a straight cut with a cheap band saw?
I’ve watched as many videos on youtube as I could find.
Thanks
Dennis
-- If we learn from our mistakes, I should be a genius!
11 replies so far
View dhazelton's profile (online now)
dhazelton
2778 posts in 2350 days
#1 posted 03-18-2014 12:35 PM
If the tension is too loose or the guide and blocks are set too high and not close to the workpiece it will wander. If those things are in order I can’t offer any more.
View johnstoneb's profile
johnstoneb
2970 posts in 2226 days
#2 posted 03-18-2014 12:56 PM
It is probably the blade. The set is stamped into bandsaw blades and it is very dificult to get the same set on both sides of the blade. This will cause the blade wander as you call it to one side or the other. If using a fence angle your wood until it is cutting straight turn of saw with out moving wood then angle fence to match angle of the wood. The saw should cut straight then. You may want to try a different or better quality blade that may help.
-- Bruce, Boise, ID
Farrout
#3 posted 03-18-2014 02:30 PM
Thanks for that.
Any recommendations on where to buy 70” bands?
I think I found the one I have on Amazon.
It’s not a popular size.
View TheDane's profile
TheDane
5461 posts in 3717 days
#4 posted 03-18-2014 02:35 PM
I had one of those saws … always had problems with the blades I bought from Sears.
Finally solved the problem with Timberwolf blades (see: http://www.suffolkmachinery.com ). Also had good luck with Woodslicer blades from Highland (see: http://www.highlandwoodworking.com/ ).
View jfastman's profile
jfastman
10 posts in 1584 days
#5 posted 03-18-2014 02:49 PM
I just purchased the Craftsman 10” about a month ago and have the same problem with the 70.5” Sears brand blades. My old Ryobi cut better than the Craftsman. I was looking for the same information. Thanks “TheDane” for the links.
117160 posts in 3631 days
#6 posted 03-18-2014 03:05 PM
follow the tips on this video and it should solve any problems you have with your band saw.
https://www.youtube.com/watch?v=wGbZqWac0jU
View distrbd's profile
distrbd
2252 posts in 2500 days
#7 posted 03-18-2014 03:09 PM
Most of the problem with blade wandering on a bandsaw in my opinion is related to the blade itself,a bad weld would be the very first thing I would suspect,although it’s hard to visibly detect it but if you feel a small lump or an indentation at the weld,then you will most likely have a wandering blade.
-- Ken from Ontario, Canada
View shipwright's profile
shipwright
8006 posts in 2852 days
#8 posted 03-18-2014 03:11 PM
I’m really impressed with Diamond Sterling blades. Here is a blog showing how well one of them tracked on my 11” Shopsmith BS. They are sold by the inch. The one in the blog is 15 cents /inch. For you that’s $10.50.
View DrDirt's profile
DrDirt
4426 posts in 3796 days
#9 posted 03-18-2014 04:10 PM
I like Alex’s approach – - in the Video A1Jim posted.
I would look for gunk on the tires.
DONT try to make the wheels coplaner. the Top wheel tracking is the important one – the lower wheel is just to give the blade a path back to the top wheel.
it is the top wheel +top guide that determine what is happening on your workpiece. European bandsaws don’t even have lower guides.
Farrout
#10 posted 03-22-2014 06:58 PM
I ordered the 1406PC Timberwolf band saw blade from Suffolk.
I ordered the 70”, but should hve ordered the 70.5”.
It fit, but just barely.
I had a piece of 2” pine I had previously made a slice on, to compare.
Here is a picture.
I made two cuts with the new blade and am amazed at the result. I didn’t think my little saw would do it based on the last performance.
I cut a slice as think as I could and it turned out excellent.
Picture of stock.
Picture of slice.
Thickness:
end .047
middle .039
other end .042
This represents two cuts. I can live with that.
TheDane
#11 posted 03-22-2014 07:16 PM
Farrout—I have seen new, high-end bandsaws with crappy blades that don’t cut worth a hoot. At the same time, there are a lot of guys with low-end bandsaws that are properly tuned and equipped with a quality blade that produce first-rate work.
