Pre-painting Tips - How do you do it?
Forum topic by camps764 posted 03-17-2014 09:07 PM 950 views 0 times favorited 8 replies Add to Favorites Watch
View camps764's profile
camps764
867 posts in 2323 days
03-17-2014 09:07 PM
Hey Ya’ll, I’ve got a project coming up with lots of parts in hard to paint places – it’s a bed with square spindles on the head and foot board.
On the last bed I built like this I painted everything AFTER glue up – I was afraid the paint would interfere with the glue on the joinery. To be honest, it was a big PITA to paint the spindles and get a decent finish on everything.
For the second go ‘round I was planning to paint everything before assembly.
I think I want to tape off the tenons, but am struggling with how to keep the paint out of the mortises…what are your best practices for this?
Do you just paint REALLY carefully around the mortises? Make little wooden mortise plugs to be removed after you paint? Just suck it up and paint after the assembly and glue up? Not worry because the paint in the mortises won’t matter?
-- Steve
8 replies so far
4949 posts in 2457 days
#1 posted 03-17-2014 09:30 PM
It might be easiest to plug the mortises, if you get a square dowel and cut it into whatever length you want it shouldn’t cost too much and be fairly easy. If those spindles are trapped, I would consider not gluing them in, which also means you wouldn’t have to worry about the paint being on the glued surfaces.
camps764
#2 posted 03-17-2014 09:31 PM
Fred – good suggestion, didn’t think of the square dowels.
-- Steve
View DeLayne Peck's profile
DeLayne Peck
533 posts in 2165 days
#3 posted 03-17-2014 10:05 PM
Man up, camps! Lol. Joyce and I team painted this wonder of the world after assembly. One hundred and twenty (120) balusters painted by hand, three coats, primer and 2 coats of Behr exterior.
But, seriously, I’d suggest taping off the ends of the spindles. Paint them, assemble and glue. Then paint your receiving parts.
-- DJ Peck, Lincoln Nebraska. Lord, keep your arm around my shoulder and your hand over my mouth.
View SuperCubber's profile
SuperCubber
1022 posts in 2248 days
#4 posted 03-17-2014 10:54 PM
I read a good tip for this in a magazine once (can’t remember which one). Depending on the size of the mortises, you can possibly buy some oversized foam backer rod, and shove it in the mortises while you paint. You can get a whole roll for just a few bucks.
-- Joe | Spartanburg, SC | "To give anything less than your best is to sacrafice the gift." - Steve Prefontaine
View AandCstyle's profile (online now)
AandCstyle
3024 posts in 2220 days
#5 posted 03-17-2014 11:24 PM
I use blue painters’ tape. Rip an adequate length off the roll then bend it so it is an oval shape with the sticky side out. Slide that into the mortise and use a small piece of scrap to press the tape against the sides of the mortise. The tape doesn’t need to go very far into the mortise, maybe 3/8-1/2”. Then fold the bit sticking out the top of the mortise over to make a bit of a cap over the top of the mortise. This sounds tougher than it is and I could have done 2-3 mortises in the time it took me to type this.
I have never painted using this process but I have applied stain with a rag and sprayed clear coats over that without anything getting into the mortises. FWIW
-- Art
camps764
#6 posted 03-18-2014 12:06 AM
Ha you’ve got me beat DJ. I won’t complain about spindles ever again…painted or otherwise. I’ve seen your porch project before and forget how awesome it was. Thanks for the reminder post :)
-- Steve
View lepelerin's profile
lepelerin
495 posts in 2288 days
#7 posted 03-18-2014 01:12 AM
+1 for the foam backer rod. I think we read the same magazine, I think on was in shopnotes.
View Clint Searl's profile
Clint Searl
1533 posts in 2325 days
#8 posted 03-20-2014 02:02 AM
Use a foam roller before assembly.
