Table apron help
Forum topic by RT31 posted 03-17-2014 04:56 AM 847 views 0 times favorited 6 replies Add to Favorites Watch
View RT31's profile
RT31
54 posts in 1559 days
03-17-2014 04:56 AM
Hi everyone
I have a small problem and am looking for advice.
I am building a dining room table for my house. My wife showed me a picture of a table she liked and asked if i could make something similar so of course i said yes. The table she showed me had the aprons on the outside of the legs, sitting on a rabbet it seemed. So thats what i did. The aprons are on the outside of the legs, they are flush with the legs and are mitered together at the ends. (i’ll try and take pictures tomorrow if that will help) Oh and the top is cut flush with the apron.
Now my problem is ALL the aprons are bowed out in the middle. The table is rock solid with no rock or racking even without the top. Measured diagonally, it is perfectly square. But measured across there is a 1/2 to 3/4 inch increase in the middle of the aprons compared to measuring at the ends.
How should i get rid of this bow? would it be ok if i cut a piece of wood to fit and toe screw it in place, sucking the aprons in. Or is that a ticking time bomb? Should i plane the middles of the apron down or will that comprise the strength of the table? What should i do?
View pintodeluxe's profile
pintodeluxe
5565 posts in 2716 days
#1 posted 03-17-2014 05:23 AM
Add a couple stretchers across the table to stiffen it up. They are just like aprons, but on the inside of the existing aprons. You can attach it with pocket screws.
Also, you can attach the top with figure 8 fasteners which will help stabilize the aprons.
View Rick_M's profile
Rick_M
11086 posts in 2283 days
#2 posted 03-17-2014 05:55 AM
View Monte Pittman's profile (online now)
Monte Pittman
28131 posts in 2241 days
#3 posted 03-17-2014 07:59 AM
+1 also on the stretchers. More support is always good.
-- Mother Nature created it, I just assemble it.
View crank49's profile
crank49
4029 posts in 2873 days
#4 posted 03-17-2014 01:07 PM
Another +1 on the stretcher(s) and pocket screws to attach. Or you could use small corner or angle brackets to attach.
View oldnovice's profile
oldnovice
6537 posts in 3270 days
#5 posted 03-17-2014 04:03 PM
+1 with all above!
View bandit571's profile
bandit571
19157 posts in 2586 days
#6 posted 03-17-2014 04:12 PM
Lets see IF I can find a couple photos
Ah, there’s one.
A detail shot, of how I attach to the top of the tables. Slotted hole holds a screw that goes into the table’s top
Yep, just add a stretcher across from front to back.
