Should I do this????
Forum topic by WildmanJack posted 03-17-2014 12:31 AM 1351 views 0 times favorited 19 replies Add to Favorites Watch
View WildmanJack's profile
WildmanJack
33 posts in 1669 days
03-17-2014 12:31 AM
Hey folks, I have an old, Craftsman 10” table saw. It has a the original motor and I’m wondering if upgrading to a 2HP would improve it’s capabilities. I noticed that when cutting anything thicker than 1 1/2 it starts to bog down during the cut. Any suggestions would be of great heap. Thanks…
-- Just an old banjo player tryin my hand at woodworking.
19 replies so far
View Kryptic's profile
Kryptic
294 posts in 1744 days
#1 posted 03-17-2014 12:40 AM
before changing out the motor, maybe try changing the blade as people never seem to give enough credit, to keeping the part that cuts, sharp ? in the event that fails, perhaps raisng the HP might help, but I would check out first, if the saw comes with an upgraded HP, as saws are engineered to the minimum standards of their maximum performance and so… exceeding the manufacturers specs, might not be wise
WildmanJack
#2 posted 03-17-2014 12:51 AM
Kryptic, The blade is a new Diablo from Home Depot. so I know it’s sharp, well as sharp as a blade from the big box stores can be. The saw is from around 1953 or so, pretty old Craftsman all cast Iron but I guess I can do a search and see if I can put a bigger blade on it. Thanks for the quick reply..
18665 posts in 1940 days
#3 posted 03-17-2014 01:01 AM
What is the original motor? You may not need 2 hp to see a great improvement. My 1 1/2 hp has really only bogged down when cutting full depth into oak and even then if I went slow it worked fine.
View sgmdwk's profile
sgmdwk
308 posts in 1956 days
#4 posted 03-17-2014 01:14 AM
The performance of my old Craftsman saw (bought new in 1989) improved a great deal when I (1) cleaned my blades and (2) installed a linked belt. I still don’t try to cut through 2” of hardwood in one pass. I make several graduated cuts and get the job done, just fine.
-- Dave K.
Kryptic
#5 posted 03-17-2014 01:45 AM
there ya go
many voices that concur
clean and or sharpen your blade
and sneak up on the last cut ?
View Loren's profile
10477 posts in 3731 days
#6 posted 03-17-2014 02:09 AM
2 horses is good. 3 or more is better. I had a 12” INCA
cabinet saw with a 2.5hp motor and it was a good saw.
You’ll get easier cutting with a thin kerf blade: 3/32” vs
1/8” for full kerf.
Also, if you cut softwoods and you have pitch stuck on
the blade that can decrease performance. I soak
pitchy blades in detergent water and that softens
the gunk enough to get it off with a nylon bristle brush.
Works on band saw blades too. Carbide tips don’t
rust but band saw blades will so it’s important to dry
them or if it’s sunny I just lay them out and they
dry quick enough.
View bondogaposis's profile
bondogaposis
4896 posts in 2435 days
#7 posted 03-17-2014 02:17 AM
A thin kerf blade will give 25% more HP, well not really, but in theory cutting will take 25% less effort.
-- Bondo Gaposis
View sawdustjunkie's profile
sawdustjunkie
384 posts in 1800 days
#8 posted 03-17-2014 02:32 AM
My Craftsman 113 has a 1.5 hp motor. I only use thin kerf and have cut up to 6/4 hard maple and thicker in soft woods without any problems.
I am however looking into a new saw sometime this summer.
-- Steve: Franklin, WI
Kryptic
#9 posted 03-17-2014 02:37 AM
the biggest contributing factor to letting the wind out of the sails of a carbide tooth, to the dismay of most, is not abrasion from carbide, to wood, rather the exposure of moisture, thus corrosion of the carbide ….Loren ?
the thin kerf blades work best cutting thin stock
WildmanJack
#10 posted 03-17-2014 12:50 PM
OK, I think what I’ll do is invest in a link belt, and like the suggestion, “sneak” up on thick cuts. Thanks guys great input My Craftsman is a 113 as well. Probably ought to invest in a decent thin kerf blade from somewhere other than Home D.
Thanks again,,,
Jack
View bbc557ci's profile
bbc557ci
595 posts in 2157 days
#11 posted 03-17-2014 01:42 PM
Diablo blades are as good as most any other. Link belt may or may not help? Thin kerf Diablo should be just fine. Also, Diablo also makes a good ripper in a 24 tooth blade, maybe a 30 too. I’d suggest a 24 or 30 thin blade for ripping.
-- Bill, central NY...no where near the "big apple"
WildmanJack
#12 posted 03-17-2014 01:45 PM
Thanks Bill, Sure appreciate the info..
View F Ben Kautz's profile
F Ben Kautz
32 posts in 2695 days
#13 posted 03-18-2014 10:29 PM
I use a linked belt and pulleys which up the speed.
My Forrest thin kerf blade really is great.
Make sure the fence is set right.
I installed a Delta T2 fence on my old Craftstman and it made a big difference in accuracy.
My old saw is a 3/4 hp motor and it does pretty well.
-- Woodsurgin
WildmanJack
#14 posted 03-18-2014 10:36 PM
The fence on my old Craftsman is about as useless as anything. I do need to buy a new one.. Taking measurements at the blade front and back for EVERY cut is a total pain..
Jack
View toolie's profile
toolie
2138 posts in 2712 days
#15 posted 03-19-2014 01:38 AM
i have a similar 113 series c-man and it rips 8/4 hardwoods with no burning. i need to use a ripping blade (24-30T with and aggressive hook angle), keep the carbide teeth just above the top of the work piece so the gullets can clear the saw dust and i moderate my feed rate. 2 hp wouldn’t really make much of a difference.
