Getting the D**M Finish right! Help....Poly on painted surface
Forum topic by DocSavage45 posted 03-17-2014 12:08 AM 1400 views 0 times favorited 20 replies Add to Favorites Watch
View DocSavage45's profile
DocSavage45
8549 posts in 2837 days
03-17-2014 12:08 AM
Topic tags/keywords: question finishing
I need some suggestions to end my finishing nightmare on my desk top.
I put a coat of clear Oil based poly over 2 coats of Rustolium Espresso color spray paint. Used the paint because that’s what was available. Covering a desk top that had light and dark woods laminated together. Found this after sanding off old finish.
Made the decision to put clear oil based poly on as a hard surface finish, but it was waaaay too glossy, and there were many little bubbles and some hair although I wiped and swept and wiped again before applying the poly.
Used some 00# fine steel wool after letting it set for 48 hours.
I remember being told that the gloss could be rubbed down to a satin finish.
Well the surface is smooth, but scratches are really noticeable.
I quit for now!
What steps can be taken to reduce the obvious scratches?
Thanks
Tom
-- Cau Haus Designs, Thomas J. Tieffenbacher
20 replies so far
View Clint Searl's profile
Clint Searl
1533 posts in 2356 days
#1 posted 03-17-2014 12:19 AM
Auto rubbing compound.
View Paul Maurer's profile
Paul Maurer
162 posts in 1549 days
#2 posted 03-17-2014 12:19 AM
Wax and buff?
117090 posts in 3572 days
#3 posted 03-17-2014 12:24 AM
You may need to recoat the poly ,make sure it’s completely dry and then use a series of finer grits up to 800-1200 grit.
View grizzman's profile
grizzman
7836 posts in 3298 days
#4 posted 03-17-2014 12:29 AM
a six foot deep hole and 2 sticks of dynomite….LOL… SORRY tom, me wood and paint dont get along at all…good luck…
-- GRIZZMAN ...[''''']
DocSavage45
#5 posted 03-17-2014 12:32 AM
Jim,
Thanks. Reading online re: floors and poly saying 30 days for complete hardening?
DocSavage45
#6 posted 03-17-2014 12:34 AM
Clint,
Thanks,
Have the rubbing compound and polishing compound. This would be fine enough to eliminate the scratches?
DocSavage45
#7 posted 03-17-2014 12:36 AM
Grizz,
As I told Kiefer I’m truely learning patience. Way to much time in this piece of….. to blow it up, although it might be fun?
Shawn Masterson
1325 posts in 1943 days
#8 posted 03-17-2014 12:37 AM
how about getting satin poly
View Monte Pittman's profile
Monte Pittman
29221 posts in 2333 days
#9 posted 03-17-2014 01:34 AM
I would probably go with a couple coats of satin finish. It would take less time than a lot of sanding and other finishing.
View Grandpa's profile
Grandpa
3259 posts in 2670 days
#10 posted 03-17-2014 01:48 AM
The steel wool was too course. Put on more finish and make the last coat or two satin.
View bondogaposis's profile (online now)
bondogaposis
4723 posts in 2346 days
#11 posted 03-17-2014 02:29 AM
00 steel wool is too coarse, drop down to 0000 then got to polishing compound.
-- Bondo Gaposis
DocSavage45
#12 posted 03-17-2014 02:37 AM
I think that’s what I thought I was doing. LOL!
Have to check my local Ace.
Thanks
View Snookie's profile
Snookie
173 posts in 2487 days
#13 posted 03-17-2014 11:02 AM
I would try several coats of satin poly first sanding with 0000 steel wool first before the satin poly!!!
-- Snookie, Jasper,GA
View Benji Reyes's profile
Benji Reyes
331 posts in 3073 days
#14 posted 03-17-2014 01:32 PM
Haven’t tried this finish Tom but based on your description on the finish, I would and it down to 1000 grit then finish it off with automotive rubbing compound. I hope it works.
-- Benji Reyes, Antipolo, Philippines, http://www.facebook.com/pages/Benji-Reyes/88321902103?ref=ts
View hydro's profile
hydro
208 posts in 1747 days
#15 posted 03-17-2014 03:58 PM
Most of these replies sound like an awful lot of work. Why not make it simple?
If it were my project, I would sand with 220 paper, just enough to knock off the hair and nubs, tack off the surface, and re-spray with poly of the surface sheen you are looking for. I do this all the time, and always, the surface after the first coat is full of stuff, and after that second coat it is much smoother and has a finished look.
Try a “Satin” poly for the next coat.
-- Minnesota Woodworkers Guild, Past President, Lifetime member.
