| Forum topic by Padre | posted 326 days ago | 1034 views | 0 times favorited | 4 replies | ![]() |
326 days ago |
Hi all, I have finally put together my dust collection system. I started with the Clearvue 1800LH model that has the 5hp 240v motor. I then ran 6” ASTM 3034/SDR35 (green) with the white SDR35 wyes and 45 degree elbows. Here are my questions: 1. If I take 1.5” screws and screw them into each PVC section, then run a small diameter yet solid copper wire from screw to screw on the outside, and finally finish up at the cyclone and ground it to the motor mount, will this take care of the static build-up and effectively ground both inside and outside of the pvc piping? 2. Will the 1.5 inch screws act as ‘catchers’ for debris inside the pipe? 3. Does each section (ie: each leg going to a piece of equipment) need to be grounded individually? Thanks all, this one has me stumped. -- Chip -- Manchester, Connecticut "When the power of love overcomes the love of power, the world will know peace." |
