Kerfing
« back to Joinery forum
Forum topic by rkwoods posted 03-16-2014 12:54 PM 1140 views 0 times favorited 9 replies Add to Favorites Watch
View rkwoods's profile
rkwoods
26 posts in 1980 days
03-16-2014 12:54 PM
I built a curved banquette by kerfing some 1/2’inch birch plywood. As this was my first time kerfing and building a banquette, I didn’t think I could kerf a whole sheet of plywood for the back rest so I did it in three sections and filled the horizontal seams with wood putty. I think I need to reinforce these seams somehow. Any suggestions?
9 replies so far
View Woodknack's profile
Woodknack
11608 posts in 2375 days
#1 posted 03-17-2014 05:41 AM
You’ll probably need to post a picture to get meaningful answers. Do you have a support structure behind the joints?
View Loren's profile
10377 posts in 3643 days
#2 posted 03-17-2014 05:48 AM
Does it have to look good or can it be messy?
Thin bending plywood (Italian bending ply) can
be glued and stapled from the back with 3/8”
crown staples. That will fix the bend well. It’s
probably one of the quicker ways to get this
done. I would use plastic resin glue and a lot of
staples. Contact cement could work without staples
but I’d be concerned about voids.
rkwoods
#3 posted 03-17-2014 12:48 PM
Here’s a photo of the back. I built this to hide two poles down in my basement.
rkwoods
#4 posted 03-17-2014 12:51 PM
Here’s a photo of the front
View waho6o9's profile (online now)
waho6o9
8188 posts in 2572 days
#5 posted 03-17-2014 12:58 PM
Bondo?
rkwoods
#6 posted 03-17-2014 02:38 PM
Thought about Bondo. Probably a lot easier than fiberglass.
View oldnovice's profile
oldnovice
6843 posts in 3363 days
#7 posted 03-17-2014 04:09 PM
Make sure that you have plenty of ventilation and no sources of sparks/flames in the area if you use Bondo!
Ventilation for yourself and no spark/flames for the Bondo fumes.
rkwoods
#8 posted 03-17-2014 04:15 PM
I used to restore cars years ago and have used Bondo. Thanks!
Woodknack
#9 posted 03-17-2014 04:45 PM
Ah, okay, I was thinking the seams were vertical. I would worry the bondo is too brittle and any flexing will crack it. Loren’s idea of backing the seams with glued plywood seems like a safer bet.
