Can Someone Please Help Me to Stop Burning Wood with my Table Saw?
Forum topic by Jerry posted 03-16-2014 01:34 AM 3262 views 0 times favorited 47 replies Add to Favorites Watch
View Jerry's profile
Jerry
2516 posts in 1520 days
03-16-2014 01:34 AM
Topic tags/keywords: question maple tablesaw milling
I’m using a Shopsmith, and a Makita 10” hollow ground planer blade. The machine is set on the lowest saw speed setting. I canNOT seem to cut Maple without burning the heck out of it. I’ve tried a couple of different blades with no luck. Could someone please explain to me the error of my ways and possibly offer a solution? Thanks everybody.
-- There are good ships and there are wood ships, the ships that sail the sea, but the best ships are friendships and may they always be. http://www.geraldlhunsucker.com/
47 replies so far
View ShaneA's profile
ShaneA
6878 posts in 2470 days
#1 posted 03-16-2014 01:38 AM
Outside of feed rate, blade sharpness, and height…make sure the fence is in proper alignment and the blade is clean.
View Purrmaster's profile
Purrmaster
915 posts in 1965 days
#2 posted 03-16-2014 01:48 AM
I’m not familiar with your particular machine but if your table saw is burning your wood (something I’ve done many times) I can think of a couple of things that might help:
If you’re ripping, use a thin kerf rip blade. I use Freud’s. When new and sharp it’s pretty potent.
If you’re feeding it in too fast that could be a problem as well. But I’ve noticed when I stop feeding the wood it can burn as well. A slow but steady feed rate is good.
You may also want to wax the table and the fence to let the wood move a little more easily.
View mahdee's profile
mahdee
3830 posts in 1639 days
#3 posted 03-16-2014 02:00 AM
Certain woods like cherry and maple have a lot of sugary sap in them. If they were cut in the spring or early fall, the sap has not had the time to go to the root in fall and obviously was flowing during Spring time. My only suggestion is to cut it 4 turns of your saw blade height adjustment at a time and keep the lumber flush against the fence. Hope that works for you. Also, be sure to clean your saw tooth after cutting woods like maple, cherry and hickory.
-- earthartandfoods.com
View kdc68's profile
kdc68
2636 posts in 2148 days
#4 posted 03-16-2014 03:25 AM
Certain woods are just prone to burning…maple is one of them
I tend to rip maple a strong 1/16” over sized and make a second pass at final width to clean up the edge. I find doing it this way there is less heat and friction and thus less likely to burn
-- Measure "at least" twice and cut once
View GrandpaLen's profile
GrandpaLen
1648 posts in 2144 days
#5 posted 03-16-2014 12:42 PM
+ 1 for kdc68.
If your blade is clean and sharp and you’ve tweaked all of the alignments, then a final trim to your finished size will generate less heat.
Best Regards. – Grandpa Len
Work Safely and have Fun.
-- Mother Nature should be proud of what you've done with her tree. - Len ...just north of a stone's throw from the oHIo, river that is, in So. Indiana.
View Tkf's profile
Tkf
38 posts in 1799 days
#6 posted 03-16-2014 12:48 PM
Is your blade and fence parallel to the miter slots?
View stefang's profile
stefang
15709 posts in 3206 days
#7 posted 03-16-2014 01:00 PM
I have been cutting a lot of maple lately. The cuts on my miter saw have burned quite a bit, but not the cuts on my table saw. The table saw has a fresh blade and also a narrow kerf.
View ScottKaye's profile
ScottKaye
559 posts in 1824 days
#8 posted 03-16-2014 01:00 PM
Use of a featherboard, riving knife/splitter and a gripper have greatly minimized rip burning on my table saw.
-- "Nothing happens until you build it"
View buildingmonkey's profile
buildingmonkey
242 posts in 1419 days
#9 posted 03-16-2014 05:32 PM
When I was running an old Cman table saw, I had trouble with burning, mostly because it was so hard to get the fence parallel with the blade. I would measure from the miter groove on both ends to try to make parallel, and sometimes it would move while I was sawing, just a mess. Finally got a unisaw with a Biesemeyer fence, all those problems went away.
-- Jim from Kansas
Jerry
#10 posted 03-16-2014 05:53 PM
Thanks everybody for the information, to answer all the questions I’ve seen, I am using a rip fence and a featherboard, I’ve taken extreme measures to make sure the rip fence is parallel with the saw blade. I have a super tall fence because the maple I’m cutting is actually a maple box from which I am parting the lid, but the maple was burning when I first dimensioned the pieces for the box as well. It burned when I was cross cutting using the miter gauge and it burns when I use the fence. It burns when I use an 8” fine tooth plywood blade, and it burns when I use a 10” hollow ground planer blade with a 1/16” kerf, very similar in design to this Dewalt blade in this picture here:
I have not cleaned the blade, but I can certainly try that. As far as cutting to within 1/16 of the final dimension and then trimming after that, I’m afraid that would mess up the parting line for the box lid, so that option may not be available to me in those scenarios.
I’m wondering if perhaps a different type of saw blade, and / or a slower speed on the table saw would work better. As I mentioned, I’m using a Shopsmith, and it is a variable speed motor. I’m using it on the SAW setting, but it may be that speed is too fast for maple. Does anyone have any thoughts about the proper speed for cutting maple?
Jerry
#11 posted 03-16-2014 09:43 PM
RE: Purrmaster “For ripping, that blade seems to have a lot of teeth”
You know, you have a point…It may just be that part of the problem is too much of the saw plate is coming in contact with the wood.
I’ve also been doing some other reading on this subject, and one of my problems may be feed rate, ( or lack of it ) I read somewhere that if you slow down too much or if you stop, it will definitely burn the wood, and I’m quite sure I slowed down a lot and stopped several times to make sure I was flat against the fence.
View Jim Finn's profile
Jim Finn
2592 posts in 2793 days
#12 posted 03-16-2014 10:43 PM
For ripping I use a 24 teeth sawblade, thin kerf. Get a very very smooth cut.
Purrmaster
#13 posted 03-16-2014 11:39 PM
This is the rip blade I’ve found cuts easiest when ripping:
http://www.freudtools.com/index.php/products/product/LU87R010
I’m sure there are other good rip blades out there but this is the one I have experience with.
Jerry
#14 posted 03-16-2014 11:51 PM
Thanks Jim and Purrmaster, I took a look at that blade, it looks like the hot ticket. I’m going to run, not walk :- ) , right out the front door tomorrow and buy one
View pintodeluxe's profile
pintodeluxe
5544 posts in 2685 days
#15 posted 03-16-2014 11:57 PM
You don’t have to spend a lot of money to get a good rip blade. Go to Home Depot and get a Diablo (Freud) 1024 thin kerf rip blade. You will notice a night and day difference. My full kerf combo blade burns cherry like crazy, but the thin kerf cuts great.
showing 1 through 15 of 47 replies
