wood thickness vs. expansion
Forum topic by craven posted 324 days ago 164 views 0 times favorited 1 reply Add to Favorites Watch
View craven's profile
craven
54 posts in 469 days
324 days ago
I hate to bring up a topic that may have have been discussed in here before, so please forgive me. My question has to do with seasonal wood movement (expansion) and thickness, or shall we say “thinness”. I have seen presented as a rule of thumb, that some wood species may expand across the grain up to 3/8 inch per foot, any comments or corrections? What about the thickness?... can you contain the movement by milling the thickness to 1/4 or 3/16 of an inch?... even 1/8 inch? I realize it can be laminated to MDF or plywood to control, but at what thicknesses??? I would appreciate any thoughts. Craven
-- let the chips fly!
View childress's profile
childress
163 posts in 439 days
324 days ago
The thickness doesn’t really matter. It’s all about the grain… a flatsawn board will move the most, that’s because wood moves the most with the tangential grain (flatsawn). Second most movement comes from quartersawn (radial grain), but it usually is ALOT less noticable than flatsawn (tangential) grain. If you’re that worried, try to get quatersawn, or riftsawn material. But then you have virtical lines for grain rather than cascade grain look. Also, like you said, it depends on the species of wood. You can pick up “understanding wood” by R. Bruce Hoadley as he describes in detail about wood movement according to species. Hope this helps.
-- Childress Woodworks
