miter saw question
Forum topic by woodworkingdrew posted 03-16-2014 12:33 AM 1492 views 0 times favorited 32 replies Add to Favorites Watch
View woodworkingdrew's profile
woodworkingdrew
190 posts in 1631 days
03-16-2014 12:33 AM
I currently have a ridgid 10” miter saw which I really like. Seems to cut well, alignment is good, and has enough power to cut through thick stock. My question is, would I notice a huge difference if I upgraded to a 12” saw? Is the cutting width significantly bigger then with the 10”? Thanks
-- Andrew, California
32 replies so far
View Monte Pittman's profile (online now)
Monte Pittman
29383 posts in 2361 days
#1 posted 03-16-2014 12:39 AM
12” sliding compound to me is the only way to go. Best capabilities. I would never go back to the 10”. Mine is a Dewalt.
View JFred's profile
JFred
210 posts in 1568 days
#2 posted 03-16-2014 01:02 AM
For 20 yrs I had a craftsman 10 in. miter saw and it had plenty of power, it would cut right through a 4×4 but the width of a cut board was only about a 1×10, but I needed a saw to cut wider boards, so I bought a rigid 12 in. sliding miter saw and it will cut 4×4’s, 1×12’s, maybe upto 15” wide and not sure yet if it will cut through a 6×6.
So it just depends on what you wood use it for as to which one you’ll need.
View Paul's profile
Paul
721 posts in 1588 days
#3 posted 03-16-2014 01:07 AM
My current 10” slider gets me through everything I have needed it to. It’s a P.O.S. Ryobi. It will cut 2×12’s, I don’t do much cross cutting more than 6”’s on it, anything longer than that usually goes over to the table saw.
I can’t imagine needing more than a 10” slider for anything I currently do.
Paul
woodworkingdrew
#4 posted 03-16-2014 01:31 AM
I failed to mention, I currently have a stationary saw and would replace it with another one. I am not interested in purchasing a slider. I have a circular saw to do wide boards.
View Grandpa's profile
Grandpa
3259 posts in 2698 days
#5 posted 03-16-2014 02:25 AM
If you were cutting large Crown molding you would see the difference. I believe 5-1/2 inch would need the larger saw. I have an OLD Rockwell 9 inch. I went to a job and saw what the customer wanted and my saw wouldn’t do it. HE had a 10 inch and told me to feel free to use it. It wouldn’t cut any deeper than my 9 inch. I got a 12 inch and it worked fine. That was my experience. I own a Bosch 12 inch slider now. I like it but it doesn’t stay accurate very long. My old 9 inch stays dead on. I have used a 12 inch Dewalt a lot and was satisfied with it. You will pay more for the blades. They make 10 inch sliders. They might be a compromise if you could bring yourself to own a slider.
woodworkingdrew
#6 posted 03-16-2014 02:42 AM
I think my main question is, what is the maximum width stock I can cut? Would like a comparison between the 10 and 12 inch
View basswood's profile
basswood
261 posts in 1643 days
#7 posted 03-16-2014 02:49 AM
If the build quality of the two sizes of saws were identical, a 10” saw will produce superior cut quality due to a smaller diameter blade having less runout.
The reason for the switch to a 12” saw is capacity, not quality.
The single most versatile saw on the market will be the 10” slider. And in the Kapex, provides the cut quality and lighter weight of a 10” saw and nearly the capacity of a 12” saw due to an innovative design.
Presently, the largest capacity in a non-slider 12” CMS is the DeWalt. Delta used to have the 12” saw with the greatest capacity of any CMS, but that saw was discontinued.
Expect a 10” CMS to cut a 1×6 flat or 1×4 standing or a 5” nested crown.
A 12” CMS will cut roughly a 1×8 flat, 1×6 standing and 6-1/2” nested crown.
Sliders in 10 and 12” have about the same capacity in flat stock, and the 12” sliders have some gains in vertical and nested cutting, but regular 12” CMS have the greatest vertical capacity. 12” sliders are beasts to move, so best left in one spot.
-- http://www.basswoodmodular.com/Tri-Horse-Builder-Plans-p/thbp.htm
View Rick's profile
Rick
9701 posts in 3055 days
#8 posted 03-16-2014 03:01 AM
Do you have a particular brand in mind? Ridgid? Even if not you could always go to any Manufacturers Web Site and check the difference.
They usually give cutting capacities as such: Dewalt 12” will cut a 2×10 90 degrees. A 2x8 45 degrees.
These are the “Specs for the Dewalt 10 inch:
These are the “Specs for the Dewalt 12 inch:
-- LIFE is what happens when you're planning on doing Other Things!
View adaughhetee's profile
adaughhetee
104 posts in 2706 days
#9 posted 03-16-2014 03:23 AM
Another though is price of blades between 10” and 12”. I don’t see that you would gain much its 2” wider at center line of the blade, 1/4 of the blade is used so I would guesstimate it would be less than an inch difference on a 1” thick board.
woodworkingdrew
#10 posted 03-16-2014 04:05 AM
Yeah these were the specs I was after. I need to be able to make straight and miter cuts for redwood 2×6. I do a lot of planter boxes and furniture builds with redwood. Anybody ever make 45 degree miter cuts on a table saw with a miter gauge?
View Paul's profile
Paul
#11 posted 03-16-2014 04:13 AM
a 45 degree cut on a properly tuned table saw is my go to over a miter saw any day, yes I do these cuts on a miter gauge weekly.
My new TS has a 4 foot CS capacity and a 6 foot 45 degree capacity.
Paul
woodworkingdrew
#12 posted 03-16-2014 04:15 AM
PLK- Excellent picture, thanks for the detail. Is that fence attached to your miter gauge?
View Paul's profile
Paul
#13 posted 03-16-2014 04:25 AM
Yes, It’s attached to the miter gauge with 1/8” bolts that slide into the miter gauge.
Paul
woodworkingdrew
#14 posted 03-16-2014 04:27 AM
Paul this is excellent. What’s a good way to cut four boards the same length with 45 degree miters?
View pintodeluxe's profile
pintodeluxe
5702 posts in 2836 days
#15 posted 03-16-2014 04:28 AM
12” cuts a 6×6 post in one pass. Sometimes I think a sliding 10” would be just as good.
I went with a non-sliding 12” Dewalt and have been very happy.
showing 1 through 15 of 32 replies
