Forum topic by SuburbanDon | posted 03-15-2014 10:06 PM | 1178 views | 0 times favorited | 12 replies | ![]() |
Hi Guys, I’m having problem using a router table to make mortises in cherry. I have a 1/4” up-spiral bit (towards the router) and what I’m doing is feeding my piece each way towards the bit in order to get a perfectly centered mortise. This works well when I’m cutting a mortise at the end of the piece but when I do a plunge mortise, I cannot get a smooth wall – mostly on the side of the bit farthest from the fence (this seems backwards to me). I clamped on a sturdy guide rail to hold the piece against the fence, I use a lot of hand pressure, and I’m only routine 1/4” depth changes at a time, and still it chatters and turned out badly. Since the end mortises work OK I’m really perplexed why the plunge ones don’t. Any ideas would be appreciated. Don -- --- Measure twice, mis-cut, start over, repeat --- |
12 replies so far
#1 posted 03-15-2014 10:21 PM |
small spiral bits always chatter when plunging I purchased a mortiser because of this type of results try using a non spiral bit if you have no other choice they have always worked better for me -- Please check out my new stores http://woodratnest.com and http://woodshopstore.com |
#2 posted 03-15-2014 11:45 PM |
I know other’s like and praise the up cut spiral cutters but I haven’t had great success with them. It may very well be a fault of mine. I know how a straight bit will respond, but I’m never sure with the spiral bit. Glad to hear someone else has had a straight bit perform better. |
#3 posted 03-16-2014 02:48 AM |
Thanks. I’ll give it a shot tomorrow. My spiral bit was long enough for depth of mortise I want. If I still have a problem I will try firmly mounting the wood and make a jig. -- --- Measure twice, mis-cut, start over, repeat --- |
#4 posted 03-16-2014 02:59 AM |
? -- --- Measure twice, mis-cut, start over, repeat --- |
#5 posted 03-16-2014 07:19 AM |
I have to tell you the best up cut bits I have tested for a review were the White side -- Please check out my new stores http://woodratnest.com and http://woodshopstore.com |
#6 posted 03-16-2014 07:30 AM |
SuburbanDon – I agree with ???? :) |
#7 posted 03-16-2014 07:32 AM |
I too have notice the up cut spiral bits have a significant amount of chatter, must be the nature of the beast. Also the reason I got a dedicated mortiser. I am, however, considering making a horizontal mortiser somewhere down the road…. |
#8 posted 03-16-2014 08:32 AM |
I’m wondering if the spiral bits work best with the more powerful routers or if the speed setting has to be just right. Just a thought. -- Mike, an American living in Norway. |
#9 posted 03-16-2014 08:41 AM |
really i think they flex too much when they are this small I prefer the straight cutter and I done have this problem. When I am on the Woodrat 900 or 600 I have a plunge bar and a control and the mortise rail all make cutting these small mortises fast even faster than my hallow chisel mortiser -- Please check out my new stores http://woodratnest.com and http://woodshopstore.com |
#10 posted 03-16-2014 11:23 PM |
Sorry that ”?” Was not intentional. I could not delete the post. Thanks for your replies. Today I made a jig (tray with a slot) and had similar results. This was done with a straight dado bit. I will try other things. -- --- Measure twice, mis-cut, start over, repeat --- |
#11 posted 03-17-2014 03:00 AM |
I think I solved this problem but have not verified it yet. The speed may be too. I just realized it is set to 5. -- --- Measure twice, mis-cut, start over, repeat --- |
#12 posted 03-18-2014 12:43 AM |
Solved. The speed was not as important as getting a 1/2 shank bit and a slow feed rate. -- --- Measure twice, mis-cut, start over, repeat --- |
Forum | Topics |
Woodworking Skill Share
12026 |
Woodturning
2102 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1369 |
Finishing
4899 |
6689 |
28033 |
CNC Woodworking
211 |
Hand Tools
5403 |
Jigs & Fixtures
1417 |
Wood & Lumber
6223 |
1387 |
Focus on the Workspace
2152 |
1185 |
Woodworking Trade & Swap
4753 |
LumberJocks.com Site Feedback
2197 |
Coffee Lounge
8842 |
