Rookie in need of guidance with shop space
Forum topic by Chris posted 03-14-2014 09:19 PM 1623 views 0 times favorited 19 replies Add to Favorites Watch
View Chris 's profile
Chris
177 posts in 1584 days
03-14-2014 09:19 PM
Hey everyone,
Recently I was lucky enough to purchase a new house with a detached 24×24 shop. Crazy. I never thought I would be so lucky to have so much space. I am hoping to turn this shop into a mostly woodworking/DIY space. The shop seems fairly new and well built.
Please remember I am a rookie when it comes to woodworking or DIY. Where I keep running into questions is what to do with the walls? Instead of vertical studs I have these lateral 2×6 beams that attached to 6×6 beams every 6-7 feet. Most of the videos I watch about building cabinets/workbenches/etc require building off vertical studs, and the lateral studs I have aren’t exactly where I need them to be at times. Please see the pics and let me know what you all think I should do. I want to do things right in the cheapest way possible. Any guidance on if I should just put up walls of OSB? Regardless, would you just use a french cleat system on the lateral beams and hang everything on them? Any and all advice is welcome. Thanks in advance.
19 replies so far
View Blackie_'s profile
Blackie_
4883 posts in 2512 days
#1 posted 03-14-2014 09:51 PM
Chris you need to have floor support for added strength on anything you hang on the wall, those horizontal beams might be enough but with added support you wouldn’t have to worry, if you ran vertical studs and anchored them to the cross beams that would give you the support you need for hanging things. OSB as you mentioned would work as well as long as it’s also resting on the floor.
Randy
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs
Chris
#2 posted 03-14-2014 10:04 PM
Thanks Randy. How would you anchor the vertical studs?
I ask because I tried to do this on a different section of my wall and it was difficult to get the studs flush against the beams. So, I had this uneven row of 2×4’s that weren’t very strong. I just tried to use 3.5 inch screws and pre-drill.
I appreciate your help!
View BigYin's profile
BigYin
416 posts in 2416 days
#3 posted 03-14-2014 10:05 PM
vertical studs – lots of insulation – and faced with OSB will give you a sound base for a workshop
-- ... Never Apologise For Being Right ...
Blackie_
#4 posted 03-14-2014 10:13 PM
I also thought of insulation that Bigyin mentioned but wasn’t sure what the budget was, 2 1/2” 6.35 cm screws should be plenty.
Chris
#5 posted 03-14-2014 10:50 PM
So where I struggle is the actual attachment method for the 2×4’s into the 2×6’s. I am not sure how to do this correctly.
If I place a 2×4 up against the lateral beams should I be putting screws diagonally threw the wood? Or should I be going all the way through the 2×4 from one end to the other? Also, should I attach the bottom of the 2×4 to the floor somehow?
Blackie_
#6 posted 03-14-2014 10:58 PM
Chris the correct way and best support would be to notch out the 2×4 so that it over laps the beam but this means a lot of work, if I were doing it I would just lay the 2×4 up against the beams and pre-drill the holes 1/8” or 3/32” drill bit should be big enough them just run the screws through, also you need to counter sink the screw heads by using 1/4” drill bit and just barely breaking the surface so that the head sinks into the wood.
Chris
#7 posted 03-14-2014 11:06 PM
I appreciate all the help Randy. This is a really dumb question but because I just have no experience I have to ask it.
Would you pre-drill your holes from one skinny end of the 2×4 to the the side and just countersink a little? Or, would you pre-drill your holes diagnolly on the flat wide sides of each 2×4?
If I were to notch the 2×4’s could I cut the notches out with a dado blade or would I be doing that with a jigsaw? I also have a router/router table if that would be the right tool to use? Thanks again
View gamygeezer's profile
gamygeezer
166 posts in 1585 days
#8 posted 03-14-2014 11:11 PM
In this area, this construction is called a “pole barn”. Quick and cheap to build.
You could just build 2×4 wall sections to fit between the 6×6s. This would make the wall flush all the way around. Then hang OSB on that. This would give you room to use 6 inch batts for best insulation.
For how-to, look at http://wayneofthewoods.com/Tiphowtoframeawall.htm.
Ken
-- What's a vibrant young guy like me doing in a broken down old body like this?
Blackie_
#9 posted 03-14-2014 11:13 PM
Put two screws at each intersection diagonal from each other, you can add 3 for even more support if you like but 2 should be good enough.
Chris forget about the notching you don’t need to do that just but the 2×4 up against the beams.
Measure where the 2×4 intersects with the beams then pre drill the holes all the way through the 2×4 they don’t have to enter the beam just the 2×4 then where the holes were drilled you then make your counter sink hole just barely deep enough to sink the head of the screw.
View mikeevens45's profile
mikeevens45
68 posts in 1575 days
#10 posted 03-14-2014 11:53 PM
build in bookcase style shelves in the openings you gain 6 inches of depth space per wall, top, 2 sides, and a bottom with shelves inside use existing outside wall for back…screw it into 6×6 s and angle brackets on 2×6s place or build your workbench first so you can build them above the surface top of the bench. many options for storage..plus less inexpensive than sheeting the walls after putting in 2×6 studs to match the 6×6 depth…less trouble too
mike
-- as technology progresses, wood workers seem to regress...all my power tools and my favorite is a chisel and a hand plane
View Sunstealer73's profile
Sunstealer73
166 posts in 2092 days
#11 posted 03-15-2014 02:30 AM
I have a similarly built shop and studded it out with 2×6’s instead of 2×4’s. That made the face of the studs even with the inside edge of the 6×6 posts so that I can fully cover all the walls. It also let me get lots of insulation in the walls (R24 I think).
View Grandpa's profile
Grandpa
3259 posts in 2675 days
#12 posted 03-15-2014 02:48 AM
I think you should have a base plate on the floor. Even if you use OSB to cover the studs, the edge is weak and you will bump it. OOPS! the edge just broke and you have a hole in the wall. Anchor a 2×6 to the floor (or a 2×4 if you use 2×4 studs). Use TapCon screws for this. You will want a hammer drill for drilling the holes in the concrete. TapCon is a brand name. I am sure there are others but these are the screws I have seen and used. Drill the pilot hole then they will tap their own threads in the concrete. Toe nail your studs to the plate. Now you can attach the bottom edge of the wall board to the bottom place so it has more strength. You will need to add extensions to the receptacle boxes or move them out. The code tells you can’t have combustible material around the edge of the box.
gamygeezer
#13 posted 03-15-2014 01:47 PM
I would like to add to this discussion a couple of other important details.
First, I see an electrical circuit breaker box, a light switch, and two outlets in your pictures. Before you do anything to the walls, add at least a dozen 20 amp outlets around the shop on as many different circuits as your breaker box will allow. Twenty would be better for that size shop.
Second, all the insulation you can put in the walls will be useless unless you put even more in the ceiling. That will be a project, since your joists appear to be 2×6 on 4 foot centers. There is not a lot of load bearing capability there, so you might need professional help.
I see you live in Arkansas, so your winters might not be too bad. Still, my experience in Alabama is that a warm shop adds 30% to your time in the shop.
Sorry if we seem to be snowballing your question into a huge effort, but been there, done that.
Ken
View camps764's profile
camps764
867 posts in 2359 days
#14 posted 03-15-2014 01:55 PM
plenty of great advice in this thread. Good luck and make sure you post pictures along the way. Everyone on this site loves seeing shops come together.
-- Steve
Blackie_
#15 posted 03-15-2014 02:09 PM
Grandpa is correct about the base plate, sorry I failed to mention that, but… you don’t necessarily need a hammer drill or concrete screws, liquid nail will work for what you are doing, liquid nail is very, very… strong.
Note: I tested the strength of liquid nail once when building a trailer we had made a bad glue up using liquid nail and with a 4 pound sledge hammer we weren’t able to break the bond it was permanent.
Chris, I was instructing you to lay the 2×4’s flat against the 2×6’s which I feel would work well in your application but.. the correct way to build a wall let’s say you didn’t have the horizontal 2×6’s already in place then you would want your 2×4’s with edge facing out not the face of the 2×4 facing out.
Ken has great points as well.
