Vaneer tearout
Forum topic by woodworkingdrew posted 03-14-2014 01:47 AM 799 views 0 times favorited 5 replies Add to Favorites Watch
View woodworkingdrew's profile
woodworkingdrew
189 posts in 1578 days
03-14-2014 01:47 AM
I’m sure this has been a topic on here many times. Does anybody have any tips on reducing tearout on vaneer plywood? Getting ugly results and I’m pretty sure its not the wood.
-- Andrew, California
5 replies so far
View Woodendeavor's profile
Woodendeavor
276 posts in 2575 days
#1 posted 03-14-2014 02:04 AM
If you know exactly where the cut will be take a straight edge and score the veneer with a knife, no more tear out
View bondogaposis's profile
bondogaposis
4688 posts in 2320 days
#2 posted 03-14-2014 02:52 AM
Tear out is usually caused by planing. I wouldn’t expect that you would be planing plywood. Do you mean chip out from using a table saw?
-- Bondo Gaposis
woodworkingdrew
#3 posted 03-14-2014 03:57 AM
Bondo- Sorry tear out is the wrong term. I am getting chipping at the edges being cut.
bondogaposis
#4 posted 03-14-2014 05:49 AM
If you are using a table saw, put the good face up. Use a zero clearance insert and a good plywood blade. Make a very light scoring cut first then full cut,that should help. Plywood is difficult to work especially the cheaper grades.
-- Bondo Gaposis
View Targa's profile
Targa
118 posts in 1709 days
#5 posted 03-14-2014 12:26 PM
I use a zero clearance insert and sharp 60 tooth plywood blade along with putting 1 1/4” wide Blue painters tape for delicate surfaces centered on the cut line and have zero chipping. I also put the good face up.
-- Dom
