Doing round over on small parts
Forum topic by misterbig posted 03-14-2014 01:06 AM 1385 views 0 times favorited 11 replies Add to Favorites Watch
View misterbig's profile
misterbig
45 posts in 1645 days
03-14-2014 01:06 AM
Topic tags/keywords: question
I have a project that has some 1” x 2” x 3/4” pieces that I need to put a .25 radius edge on. What method would you use for this? I need a safe solution.
M
11 replies so far
View lumberjoe's profile
lumberjoe
2899 posts in 2216 days
#1 posted 03-14-2014 01:10 AM
Router table and the Grr-Ripper
View bondogaposis's profile
bondogaposis
4687 posts in 2319 days
#2 posted 03-14-2014 01:12 AM
Round over first, then cut the parts to small size
-- Bondo Gaposis
View BJODay's profile
BJODay
526 posts in 1910 days
#3 posted 03-14-2014 03:17 AM
Table top belt sander.
BJ
View jmartel's profile
jmartel
7808 posts in 2117 days
#4 posted 03-14-2014 04:39 AM
Make a long strip of 1”x3/4” pieces, put the radius on the strip, then cut to 2” lengths.
View shipwright's profile
shipwright
7966 posts in 2765 days
#5 posted 03-14-2014 04:46 AM
In this blog I routed some 1/4” x 1/8” curved mouldings to half round by using double sided tape to attach them to a pattern piece. That same idea will work for you …... safely.
View gfadvm's profile
gfadvm
14940 posts in 2657 days
#6 posted 03-15-2014 01:19 AM
I rout small pieces held in my wooden hand clamps on the router table.
View Monte Pittman's profile
Monte Pittman
28947 posts in 2305 days
#7 posted 03-15-2014 01:35 AM
If possible, do what Bondo said. If you have to cut them down first., try it the way gfadvm suggested.
-- Mother Nature created it, I just assemble it.
View NiteWalker's profile
NiteWalker
2736 posts in 2544 days
#8 posted 03-15-2014 02:18 AM
I use the double stick tape method; stick the pieces to a bigger piece of wood, clamp that down, and also double stick a scrap of the same thickness as the pieces to the bottom of the router plate so it doesn’t tip when routing.
I’ve done this quite a bit with no problems. Easy as brownies. :-)
And now I want brownies. :-p
View Marcus's profile
Marcus
1163 posts in 1987 days
#9 posted 03-15-2014 12:02 PM
Monte said exactly my thoughts. Stick with one of those 2 suggestions.
View Whiskers's profile
Whiskers
389 posts in 1994 days
#10 posted 03-16-2014 01:25 AM
Every time I seen this done it was done as bondo described, roundover a larger piece than cut to size. Would be cheaper to as that 2x lumber is usually quite expensive and has ratty edges.
View nineiron's profile
nineiron
9 posts in 1669 days
#11 posted 03-29-2014 02:55 AM
I would tend to suport “gfadvm”. But i would use A dremel router for small pieces.
-- Brian, Australia N/I
