Forum topic by Belg1960 | posted 03-13-2014 05:29 PM | 1803 views | 0 times favorited | 9 replies | ![]() |
Good morning, as some of you know I recently built my niece a frame and bodged a clamping system. Shown at this link. http://www.workshopaddict.com/forum/...8-12.15.08.jpg My biggest problem was I could not turn it over because the outside corner braces would then not hold. I had to hope the joints were closed when the glue was dry. I would like to be able to clamp with the money side facing up. -- ***Pat*** Rookie woodworker looking for an education!!! |
9 replies so far
#1 posted 03-14-2014 01:43 AM |
I would just pin it together with a 23 gauge pin and let the glue set up |
#2 posted 03-14-2014 11:58 AM |
I would glue on some angled blocks parallel to the mitre that would allow my clamps to pull the joint together then cut them off after it was glued. You need something to reinforce the joint, dowel or loose tenon |
#3 posted 03-14-2014 12:37 PM |
I agree with the idea to glue on the blocks. Just a tiny dab of glue, then cut them off as close to the good wood as possible, then plane off the rest. Easy. -- - The mightiest oak in the forest is just a little nut that held its ground. |
#4 posted 03-14-2014 12:54 PM |
You can also use miter clamps or spring clamps. This is an article I wrote on them for Old House Journal: http://www.oldhouseonline.com/tool-review-miter-clamps/ -- http://www.basswoodmodular.com/Tri-Horse-Builder-Plans-p/thbp.htm |
#5 posted 03-14-2014 01:04 PM |
Here is a photo of crown with the Collins Clamps on a Victorian door casing project. They are handy in the shop as well. -- http://www.basswoodmodular.com/Tri-Horse-Builder-Plans-p/thbp.htm |
#6 posted 03-14-2014 01:12 PM |
Do they leave marks on the wood? -- - The mightiest oak in the forest is just a little nut that held its ground. |
#7 posted 03-15-2014 03:06 AM |
I put all of these compound miters together with the Collins Clamps, so only the slightest of marks. Less than an 18 gauge pin. -- http://www.basswoodmodular.com/Tri-Horse-Builder-Plans-p/thbp.htm |
#8 posted 03-16-2014 03:16 PM |
Pat, I would spread the glue and rub the two pieces together. You’d be surprised how they will hold. You will have to glue only one corner at a time though, let’s say about one hour delay. Another option would be using both hotmelt glue and carpenter’s glue. A dab of hotmelt glue in the center of one piece and carpenter’s glue around it. Hand press the joint and the hotmelt glue will hold the joint while the carpenter’s glue will dry out. I also like the spring clamp option. Good luck ! Serge http://atelierdubricoleur.wordpress.com -- Learn from yesterday, work today and enjoy success tomorrow. -- http://atelierdubricoleur.wordpress.com |
#9 posted 03-17-2014 11:11 AM |
Guys, thanks for all the suggestions. I’m not sure I want to use the spring clamps as they would leave marks on my mahogany. -- ***Pat*** Rookie woodworker looking for an education!!! |
Forum | Topics |
Woodworking Skill Share
12031 |
Woodturning
2108 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4905 |
6695 |
28061 |
CNC Woodworking
212 |
Hand Tools
5411 |
Jigs & Fixtures
1420 |
Wood & Lumber
6233 |
1388 |
Focus on the Workspace
2154 |
1187 |
Woodworking Trade & Swap
4757 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8845 |
