Ridgid MS1065LZ miter saw blade run out?
Forum topic by bigblockyeti posted 03-13-2014 03:27 PM 1417 views 0 times favorited 2 replies Add to Favorites Watch
View bigblockyeti's profile
bigblockyeti
5121 posts in 1721 days
03-13-2014 03:27 PM
After noticing a slight degradation of the cut quality on my miter saw decided to change the blade only to notice what I believe is excessive run out. Checking the previous blade as well as several others yielded the same 0.017” of wobble measured at a radius of about 4.5” from the center. The saw was manufactured in 2005 and has been used sparingly only in my shop, never on a job site so the possibility of abused is beyond unlikely. Calling Ridgid directly to get a spec on the arbor resulting in a waste of 28 minutes and zero addition information beyond what I already knew. Has anyone experienced run out on any miter saw that resulted in visible blade wobble and degraded cut quality?
2 replies so far
View TechTeacher04's profile
TechTeacher04
383 posts in 1532 days
#1 posted 03-17-2014 06:45 PM
Have you checked the blade and blade bushing. I had an issue once that the blade bushing did not seat square and had similar results. You could also have a blade that is warped.
bigblockyeti
#2 posted 04-01-2014 04:34 PM
The blade was eliminated from the equation by testing with 5 other known good blades. I’ve never seen a 10” mitersaw with a blade bushing, only seen them on 12” saws, mine does not have one. The issue turned out to be the inner arbor washer. It is of a low quality stamped steel design and must have some how been damaged. After replacement my measured runout on the plate just below the gullets was a consistent 0.003” with several different blades.
