Cauling for some tips
Forum topic by TheWoodenOyster posted 03-13-2014 03:21 AM 1021 views 0 times favorited 3 replies Add to Favorites Watch
TheWoodenOyster
1313 posts in 1897 days
03-13-2014 03:21 AM
Topic tags/keywords: glue cauls
Hey guys,
While doing a dry run for a large tabletop glue up today, I stopped and realized that I think I need to make some new clamping cauls. I tried to put a bow into the first set I made and I think I went a little overboard. My shorter cauls (18” to 24”) have about 1/16 or more camber and the longer ones (36ish”) have about 3/16 to 1/4 of camber in them. Seems like I have to put too much pressure on them to get the bow to come out. I am worried that between the camber on the top caul and the bottom caul, I am going to put a bow in the panel because the cauls somehow won’t flex at the same rate. Anyway, I have a ton of cherry left over from this tabletop and was wanting to make some new clamping cauls from the leftovers. I am thinking of leaving the camber totally out or maybe just taking three or four passes with a handplane. Any thoughts or tips on making a good long lasting set of cauls?
Thanks again guys
-- The Wood Is Your Oyster
3 replies so far
View The Box Whisperer's profile
The Box Whisperer
678 posts in 2032 days
#1 posted 03-13-2014 03:35 AM
I cant speak to your question, because I just winged it with both of my sets. The only meager tip I have for you is to wrap them in tuck tape when youre done. Ugly, but PA wood glue will never stick to it.
-- "despite you best efforts and your confidence that your smarter and faster than a saw blade at 10k rpm…. your not …." - Charles Neil
View widdle's profile
widdle
2069 posts in 2961 days
#2 posted 03-13-2014 03:43 AM
i have never probably put as much thought into it as i should..and plan to do a bit of flattening after the glue sets…
but i suppose the type of lumber the size of the cauls all act differently . make two and do a mock up ?
View waho6o9's profile
waho6o9
8160 posts in 2539 days
#3 posted 03-13-2014 04:41 AM
