Does anyone make a table saw fence that is compatible with biesemeyer rails?
Forum topic by buddx posted 03-12-2014 07:34 PM 2434 views 0 times favorited 14 replies Add to Favorites Watch
View buddx's profile
buddx
6 posts in 2530 days
03-12-2014 07:34 PM
Topic tags/keywords: tool help tablesaw fence biesemeyer hdpe tip question resource
I have a Biesemeyer fence and it has been very good to me for about five years now until I dropped it yesterday. The plywood split out and left a bubble in the side of the fence which i tried to fix with glue and a couple clamps put it is still not very true. Are there any companies out there that make a fence that would just sit right on the Biesemeyer rails I already have on my table saw? I would really like to try a fence with HDPE sides but it would appear that Biesemeyer doesn’t make a model like that. Before I drop a couple hundred on a replacement fence I thought I would check with you fine folks and see what you know. Thanks a lot!
14 replies so far
View Loren's profile
10477 posts in 3881 days
#1 posted 03-12-2014 07:43 PM
Probably, but I think it is likely you can refurbish your fence
and use HDPE if you want to.
http://www.popularwoodworking.com/woodworking-blogs/editors-blog/biesmeyer-table-saw-fence-removal-and-refacing
View CharlesA's profile
CharlesA
3355 posts in 2031 days
#2 posted 03-12-2014 07:48 PM
+1 to rehab. Another possibility (I don’t know for sure if this will work, but worth investigating) is to buy the HDPE faces for the Shop Fox Classic fence. I think they’re the same size, but not sure.
View rkober's profile
rkober
137 posts in 2526 days
#3 posted 03-12-2014 08:05 PM
+1 to rehab but here’s an alternative to check out:
http://vsctools.com/product-details/table-saw-fence/
-- Ray - Spokane, WA - “Most people don’t recognize opportunity because it’s usually disguised as hard work.” - Unknown
View John Stegall's profile
John Stegall
514 posts in 3750 days
#4 posted 03-12-2014 08:33 PM
Another +1 on the Popular Woodworking rebuild. Lots cheaper than 200$
-- jstegall
buddx
#5 posted 03-12-2014 09:03 PM
Thanks for the info guys! I think you might be drastically overestimating my level of handiness but what I lack in ability I’ll make up in try. Any ideas on where to buy some HDPE? Have any of you used it with a saw fence? Is it even worth it? I have always thought it would work better but have never even touched a fence made of it let alone used one. Thanks again guys!
CharlesA
#6 posted 03-12-2014 09:07 PM
Again, don’t know for sure it is the right size, but check out http://cdn0.grizzly.com/partslists/w2005_pl.pdf for the parts for the Shop Fox fence faces. might work perfectly for you, might not. You might have to drill some new holes if the dimensions are right.
buddx
#7 posted 03-12-2014 09:11 PM
Sorry Charles… I kinda skipped right by your first post there. Heh heh… My bad. Thanks!
CharlesA
#8 posted 03-12-2014 09:13 PM
No problem . . . those replacement parts may be expensive as well, but if they fit, it would be a lot easier.
View TheGermanJoiner's profile
TheGermanJoiner
847 posts in 1871 days
#9 posted 03-12-2014 09:26 PM
http://vsctools.com
-- Greg - Ferdinand and Son Construction: Do it right the first time. Like us on Facebook
View CharlesNeil's profile
CharlesNeil
2468 posts in 4104 days
#10 posted 03-12-2014 09:31 PM
The link Greg has posted of the Really Super Cool Tools, is a really good spource, I have their fence, and Its super .. Just my .02…
CharlesA
#11 posted 03-12-2014 11:08 PM
Just to clarify, what you’re saying is that the only thing damaged were the wooden (or melamine) faces on the square tubing fence, right? Everything else is okay?
The HDPE (or the like) fence faces from Shop Fox are approximately $19. I wrote customer service because I was curious.
View NiteWalker's profile
NiteWalker
2738 posts in 2810 days
#12 posted 03-13-2014 01:36 AM
+1 more for rehabbing the fence aces.
I’d use formica laminated baltic birch as the original faces are, but counterbore where the bolts are so you can easily replace the faces again later on if needed. Also, no need for the black molding on the edges. A simple 1/8” roundover will do just fine. :-)
The problem with hdpe is that it’s not always completely flat; there could be valleys or bumps in the surface.
My table saw I have arriving has hdpe faces; if they’re not flat enough for me I’ll be doing what I mentioned above.
View dogmir's profile
dogmir
25 posts in 2205 days
#13 posted 03-13-2014 01:39 AM
If it were me I would just replace the plywood pieces. Not to mention it gives you an opportunity to upgrade and add a t track to the plywood panel.
If I had to do it I would just pull the laminate off and remove the old piece of baltic birch and use it as a template to make a new one. Reattach the screws and reface with new laminate. I most likely wouldn’t bother with the t molding. If this is not something you want to make your self just Google biesemeyer fence board kit.
View Mainiac Matt 's profile
Mainiac Matt
8607 posts in 2562 days
#14 posted 03-13-2014 02:30 AM
Rehab is a breeze…
I had to strip mine down to metal and replace the plywood.
Here's my blog showing how I did it.
-- I yam what I yam and that's all what I yam
