| Forum topic by JasonK | posted 324 days ago | 147 views | 0 times favorited | 2 replies | ![]() |
324 days ago |
The project I’m working on now is a mix of plywood and hardwood. I stained the ply and sealed it with 1 coat of shellac before I started the glue up. During glue up, I had some squeeze-out. When I could, I cleaned it up as it happened with a damp towel. Now that it’s had a little time to cure, I have noticed there are some streaks on the plywood from where I wiped the glue off. Any suggestions of how to clean of that residue before I start applying the finish? -- Measure once; Cut Twice, Three Times, Four Times... |
