Wiping glue off
Forum topic by nate22 posted 03-11-2014 07:16 PM 1897 views 0 times favorited 13 replies Add to Favorites Watch
View nate22's profile
nate22
475 posts in 3051 days
03-11-2014 07:16 PM
When you guys wipe glue off after you glue something how to get it out of corners or on the inside edge. I don’t know what to use to get it out. What should I use.
-- Gracie's wooden signs. Middlebury, In.
13 replies so far
View madts's profile
madts
1872 posts in 2516 days
#1 posted 03-11-2014 07:18 PM
I use a small awl or screw driver wrapped in a damp rag to wipe the corners. Either that or leave to dry then use a chisel.
-- Thor and Odin are still the greatest of Gods.
View bigblockyeti's profile
bigblockyeti
5258 posts in 1897 days
#2 posted 03-11-2014 07:19 PM
I usually use a sharp piece of plastic, if for no other reason to drag out what I can’t get to with a rag and then wipe it up more completely. Many times glue left on the workpiece can interfere with how a finish applies.
View ChefHDAN's profile (online now)
ChefHDAN
1140 posts in 3025 days
#3 posted 03-11-2014 07:55 PM
Drinking straws, they’ll mold themselves to the inside angles and then scoop up the squeeze out into the straw, I follow with a wet towel after that
View ellen35's profile
ellen35
2738 posts in 3608 days
#4 posted 03-11-2014 08:05 PM
Dental tools… set that I got at harbor freight.
View dbhost's profile
dbhost
5767 posts in 3408 days
#5 posted 03-11-2014 08:29 PM
Another for the drinking straw trick. Depending on the finish, I typically try to apply the finish to just inside where the mating pieces cover each other during the dry fit phase… That way no potential for visible missed spots with the finish… The drinking straw thing picks up most of it, then a damp cloth on a straight blade screwdriver gets the rest.
View NiteWalker's profile
NiteWalker
2738 posts in 2753 days
#6 posted 03-11-2014 08:35 PM
I use one of the thin cheap steel rules from harbor freight.
Lasts much longer than a straw and IMHO works just as good. Small and thin enough to get wherever needed.
View Pdub's profile
Pdub
924 posts in 3356 days
#7 posted 03-11-2014 09:11 PM
I usually use an exacto knife blade followed by a wet rag, but I may have to try some of these other ideas.
-- Paul, North Dakota, USAF Ret.
View richardwootton's profile
richardwootton
1701 posts in 2131 days
#8 posted 03-11-2014 10:05 PM
I normally apply a thin coat of paste wax to areas where squeeze out is likely to occur, then pop the glue of after it’s dried for about 30 minutes to an hour with a chisel. Then I use some mineral spirits to remove the paste wax so it doesn’t interfere with my finish.
-- Richard, Hot Springs, Ar -- Galoot In Training
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 2248 days
#9 posted 03-11-2014 10:11 PM
+1 drinkin straw. cut at an angle and works like a dream. We use the thick red ones that come from sonic.. Recycling!!
-- Who is John Galt?
View lateralus819's profile
lateralus819
2241 posts in 2065 days
#10 posted 03-11-2014 10:22 PM
Chisel works good.
View Skippy906's profile
Skippy906
121 posts in 2163 days
#11 posted 03-13-2014 03:00 AM
+1 for the drinking straws. Then a utility knife and a damp rag after that.
-- Making progress
View stnich's profile
stnich
120 posts in 3100 days
#12 posted 03-14-2014 04:44 PM
If I have inside corners that are hard to get to a lot of times I’ll use painters tape
as a precautionary measure to insure that the glue doesn’t get on the places that
I don’t want. You can take it off when the glue is still wet or later when it’s cured.
When I’m edge gluing boards I wait till the glue has partly cured then I just use a
chisel to sort of peel the glue of. No water involved so no smearing the glue into the wood.
5143 posts in 2669 days
#13 posted 03-14-2014 05:27 PM
If you cut a 45ยบ angle on the end of that plastic drinking straw it works even better, or at least it seems so to me.
