What kind of scraper works best on a broad, gently curving bandsaw box?
« back to Hand Tools forum
Forum topic by HarveyDunn posted 03-11-2014 05:02 PM 755 views 0 times favorited 5 replies Add to Favorites Watch
View HarveyDunn's profile
HarveyDunn
328 posts in 1640 days
03-11-2014 05:02 PM
I’m shopping for my first scraper. My current project is a set of bandsaw boxes that are oval in shape. They range from 3” to 6” high. I don’t know how to express what their radius is, but I would say “gentle to moderate”. The original ovals on the patterns were 3” x 5” for the smallest one and 7” x 11” for the largest one.
I want to scrape them, not sand them, because I plan to dye them to bring out the figure and the finishing recipe I am following recommends scraping.
Scraping the centers should be quite straightforward, but I’m wondering whether I’ll run into trouble on the ends. I’m assuming I want a standard, rectangular scraper. Would a super thin, super flexible one be what I want for getting around the ends of the ovals?
The wood is maple.
5 replies so far
View BinghamtonEd's profile
BinghamtonEd
2286 posts in 2279 days
#1 posted 03-11-2014 05:10 PM
I think scraping is going to be more difficult than sanding in this case, since you’re trying to follow the curve of the box with a thin straight edge of metal, bowed to only contact a small surface area. If you’re concerned with the sanding not leaving a nice cut fiber, you could do 90% of the work sanding, then follow up with a scraper.
If I understand what you’re describe though, than yes, I’d use a plain rectangular scraper, unless you can find one that will fit the contour of the oval and scrape very lightly cross-grain.
View Planeman40's profile
Planeman40
1105 posts in 2670 days
#2 posted 03-11-2014 05:15 PM
Try using a single-edge razor blade. I scrape all the time with these. When they become dull, toss it away and get another one. Cost is about $5 per box of 100 ( 5 cents each) and sometimes you can get a better deal than that. I have done entire cabinets with these.
Planeman
HarveyDunn
#3 posted 03-11-2014 05:17 PM
How do you hold them (other than “very carefully”...)?
View lepelerin's profile
lepelerin
493 posts in 2234 days
#4 posted 03-11-2014 05:58 PM
I have this set from LV and so far it served me very well. From very hard to very flexible
http://www.leevalley.com/en/wood/page.aspx?p=32670&cat=1,310,41069
runswithscissors
2657 posts in 1934 days
#5 posted 03-11-2014 11:05 PM
Broken glass makes a good scraper, and it’s very cheap—as long as you aren’t buying new panes of glass to do this. Window class is the right kind. Put an old pane in a bag and smack it just enough to break it into pieces. You’ll get both concave and convex edges. Not every edge will be sharp, and the sharp edges will dull after some use. Though I suppose some will feel this is dangerous, I have rarely cut myself, and then minimally. If it concerns you, put masking tape on the edges you won’t be using.
Sometimes a straight edge will be sharp, but don’t count on it. Even for flat surfaces, you can get a more aggressive cut with a slightly convex edge.
