Questions about Stanley 93
« back to Hand Tools forum
Forum topic by ScottStewart posted 03-11-2014 01:50 AM 1032 views 0 times favorited 11 replies Add to Favorites Watch
View ScottStewart's profile
119 posts in 2062 days
03-11-2014 01:50 AM
I am debating getting a shoulder plane, and my main options seem to be the LV shoulder and the Stanley 93. Blood and Gore seems to imply that there are a lot of things that can go wrong with the 93 and caveat emptor.
Anyone use the 93?, like it, hate it, watch our for this? I am looking at one from one of the reputable online tool sellers. All opinions appreciated.
11 replies so far
View woodchuckerNJ's profile
1261 posts in 1564 days
#1 posted 03-11-2014 01:53 AM
Just my opinion, the LV planes are worth the money.
They are modern, smartly designed..
The quality is far superior to Stanley.
-- Jeff NJ
View PaulJerome's profile
57 posts in 2964 days
#2 posted 03-11-2014 01:24 PM
There’s also the LN which is excellent. I purchased the LV and haven’t looked back. Great tool. Finely machined and works like you’d expect.
-- Paul, Central Illinois
View sikrap's profile
1121 posts in 3289 days
#3 posted 03-11-2014 01:43 PM
I think that if you’re talking about the new Stanley 93’s, you would definitely be better off with LV, LN, or Clifton. Personally, I like the old Stanleys, but they are over $100, so you’d probably be better off going for the Lee Valley, especially since the vintage planes will need some work.
-- Dave, Colonie, NY
View WayneC's profile
13751 posts in 4028 days
#4 posted 03-11-2014 02:35 PM
+1 for LV or LN…
View Kaleb the Swede's profile
Kaleb the Swede
1815 posts in 1900 days
#5 posted 03-11-2014 02:45 PM
Maybe because I have never tried the Lie Nielsons but my new 93 that I got for my birthday a few months back has come into great use. I have used it to clean tenon shoulders, chisel planing off glue spots, making grooves and dados a little deeper. It has been a really good plane to have. Like I said I have never used a Lie Nielson and I have heard they are great, but don’t discount the 93.
-- Just trying to build something beautiful
View Andre's profile
1723 posts in 1736 days
#6 posted 03-11-2014 03:34 PM
Just got the LN Medium size and very impressed! More comfortable and on the hands than LV version.
View Vincent Nocito's profile
Vincent Nocito
485 posts in 3294 days
#7 posted 03-11-2014 03:36 PM
I use old Stanley 90, 93 and 93 planes. Keep the blades sharp and properly adjusted and they work fine. You might want to check ebay for old ones or perhaps a Clifton or Record. Personally, I would avoid the new Sweetheart Stanley 92 and go for an oldie instead. Even the Wood River 92 (Woodcraft modeled after the old Preston planes) is pretty decent.
View JayT's profile
5536 posts in 2141 days
#8 posted 03-11-2014 03:52 PM
Kaleb, you got a new 93? I didn’t think Stanley was making a 93 any more, just the 92.
I have a new 92 and would also say to avoid it. On the one I got, the bed for the iron was not square to the sole or the sides. Apparently, it is a common problem with the new 92’s. As much as I like vintage planes, this is one case where I think a new medium LV or LN shoulder plane would be worth it—they are not much more than a vintage 93, but you are getting something machined square and a good company to back it up if there is an issue.
View WhoMe's profile
1564 posts in 3174 days
#9 posted 03-11-2014 03:53 PM
Yep, avoid the new Stanley. All of them have sharp edges where the hands go, which requires work to smooth.
Once I learned how to use mine, I found that no matter what I do, the blade does not make an even cut. Bottom is square to the sides, blade is square, so, I save concluded that the bedding for the blade is most likely off. Not an easy fix.
It also rusts easily, even with a light coat of oil on it when I put it away.
Go for the LN or LV.
-- I'm not clumsy.. It's just the floor hates me, the tables and chairs are bullies, the wall gets in the way AAANNNDDD table saws BITE my fingers!!!.. - Mike -
View theoldfart's profile
9494 posts in 2381 days
#10 posted 03-11-2014 04:35 PM
I have the LN medium and it works superbly. Would not hesitate to recommend it.
-- "With every tool obtained, there is another that is needed" DonW ( Kevin )
10081 posts in 3578 days
#11 posted 03-11-2014 04:47 PM
I had a 92 or 93, I don’t remember which. After I got a
4lb. Record 073 I couldn’t get rid of the Stanley fast enough.
This was a long time ago, before the new crop of high-end
shoulder planes. I’ve read that old Record and Clifton shoulder
planes have variable quality but my Record is satisfactory.
My position on a shoulder plane for general furniture work
is it should be on the heavy side. The mass helps keep the
iron engaged in chatter-prone end grain cuts. For
small things you may find a small shoulder plane is good.
I like the way the knob turns sideways on the Lee Valley
