dado stack
Forum topic by Bill1234 posted 03-10-2014 03:11 PM 2014 views 0 times favorited 17 replies Add to Favorites Watch
View Bill1234's profile
Bill1234
2 posts in 1806 days
03-10-2014 03:11 PM
Topic tags/keywords: question dado
I recently bought a dado stack for my table saw only to get it home and read that it couldn’t be used on a table saw because of the high RPMs. Can anyone tell me what specifically the problem is as long as the arbor will accommodate the stack? Any suggestions for a stack that can handle 4500 RPM’s without spending a fortune?
Thanks
17 replies so far
View RockyTopScott's profile
RockyTopScott
1186 posts in 3479 days
#1 posted 03-10-2014 03:13 PM
What brand dado stack did you purchase? Might be for a Radial arm saw
-- “When you want to help people, you tell them the truth. When you want to help yourself, you tell them what they want to hear.” ― Thomas Sowell
4987 posts in 2493 days
#2 posted 03-10-2014 03:22 PM
I’ve never heard of such a thing, I’m wondering what brand it is as well.
View woodchuckerNJ's profile
woodchuckerNJ
1274 posts in 1634 days
#3 posted 03-10-2014 03:31 PM
You sure your saw is 4500?
-- Jeff NJ
View Monte Pittman's profile
Monte Pittman
29233 posts in 2338 days
#4 posted 03-10-2014 04:02 PM
If it can’t handle the RPM from your saw, don’t use. That means that it could break apart with the centrifugal force spinning. pieces would fly like bullets. It would not be good.
I would verify the RPMs of your saw. What type of dado is it?
RockyTopScott
#5 posted 03-10-2014 04:33 PM
Good point Jeff, I have a 5hp table saw and it is has a spec of 4300 rpm
View pintodeluxe's profile
pintodeluxe
5662 posts in 2813 days
#6 posted 03-10-2014 04:42 PM
I have good luck with the Freud entry level dado set. It is cheaper than most, and does a great job. I bought mine used, and have put it to regular use for years and it has never been sharpened. As long as I have a sacrificial fence on my miter gauge, the shoulders are still clean and crisp.
View bigblockyeti's profile
bigblockyeti
5121 posts in 1721 days
#7 posted 03-10-2014 05:06 PM
Never heard of a stacked dado set that can’t be used on a tablesaw. Sort of like stating a certain tire can only be used on a station wagon and not a sedan.
View Todd's profile
Todd
398 posts in 1677 days
#8 posted 03-10-2014 09:03 PM
Beats me. I have a Freud entry level set also. Does a fine job for me with occasional use.
-- Todd, Huntsville, AL
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3585 days
#9 posted 03-10-2014 09:10 PM
They are not allowed anywhere in Europe at all .All saws here cannot accomodate them as the spindles on saws in Eropean union are made purposely too short to accomodate them .Health and safety rules. Alistair.
View knotscott's profile
knotscott
8017 posts in 3376 days
#10 posted 03-10-2014 09:16 PM
What specific dado set did you buy, and what specific saw are you using it on?
Bill1234
#11 posted 03-10-2014 09:49 PM
This is a Harbor Freight set. The directions say ok for Radial Arm but not Table saw. My Skil Table Saw is actually 5,000 RPM, Dado set is 4,000 or 4,500 max.
Monte i wasn’t sure what the issue would be but had decided that it must be rated for a reason and I shouldn’t use it. You confirmed that.
Thanks for the advice.
Bill
View WhyMe's profile
WhyMe
1014 posts in 1561 days
#12 posted 03-10-2014 10:48 PM
I have two sets of dado blades. One 6 inch and the other is a 8 inch. The RPM rating is 9500 and 9000 respectively. My advice is not to buy any table saw blades from Harbor Freight.
View tefinn's profile
tefinn
1222 posts in 2437 days
#13 posted 03-10-2014 10:55 PM
You wouldn’t be happy with the HF dado set any way. They leave very rough dadoes. Neither of the HF sets are rated for table saw use. Get the Freud set available at Home Depot. It’s a decent set and won’t break the bank.
-- Tom Finnigan - Measures? We don't need no stinking measures! - Hmm, maybe thats why my project pieces don't fit.
View buildingmonkey's profile
buildingmonkey
242 posts in 1548 days
#14 posted 03-11-2014 02:18 AM
I bought an Oshlun 8” 42 tooth dado with 6 tooth center cutters from Carbide Processors for about 85$, no freight. Was going to get one for the new Hammer saw, but have not found one drilled to fit it. CP did have blades for it however, reasonable, and no shipping as well
-- Jim from Kansas
View Todd's profile
Todd
#15 posted 03-11-2014 06:06 PM
I buy some stuff from HF, but not blades for anything with the exception of my reciprocating saw. It’s not worth the frustration and lack of quality cut. I have a miter saw from HF for rough cutting but even then I replaced the blade on it almost immediately because it was so pitiful. I did the same with with a plate joiner I bought from there.
