Arm R Seal not settling on Walnut Burl
Forum topic by Woz posted 03-10-2014 01:52 PM 1306 views 0 times favorited 5 replies Add to Favorites Watch
View Woz's profile
Woz
46 posts in 2005 days
03-10-2014 01:52 PM
I am having trouble getting Semi-Gloss Arm R Seal to settle on the Burl portion of the attached. The veneer is adhered to 3/4” Baltic Birch w/ Contact Adhesive. Used Datco Natural Danish Oil on the bare veneer-allowed to dry in my Basement workshop for 3+ weeks in ambient 65-70 degree & under a fan for the last week. The arm r seal (4 coats) appears to bubble & not settle into the burl. I sanded everything off yesterday back to bare wood. Thoughts/suggestions?
5 replies so far
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3618 days
#1 posted 03-25-2014 04:13 PM
How long did the Danish oil sit before you applied the Arm R Seal? How thick was the veneer? Could the contact cement have ‘soaked’ through sealing the wood from penetration by the oil? Lots of questions but no real help.
View NiteWalker's profile
NiteWalker
2736 posts in 2483 days
#2 posted 03-25-2014 06:47 PM
Skip the danish oil. It’s not really adding anything to the project.
Also, try some of the arm-r-seal on a scrap of the burl veneer not glued down to make sure the problem isn’t the arm-r-seal.
View CharlesA's profile
CharlesA
3305 posts in 1703 days
#3 posted 03-25-2014 06:55 PM
Couple of questions: 1) I know that the satin and semi-gloss have additives that need to be stirred every 15 minutes or so or they fall out of solution. I don’t think that would affect drying or adhesion (I think it mostly makes it more glossy), but worth a look. 2) if it is not “settling” in the burl, does that mean you’re applying a thick coat? It is made for very thin coats.
If neither of these apply . . . never mind.
Shawn Masterson
1324 posts in 1854 days
#4 posted 03-25-2014 09:22 PM
The dumb question of the day. Is there any way the can may have been shaken?? I had some shellac that someone walked by and shook while I was out on a call. It cause fish eyes all over.
View Woz's profile
Woz
#5 posted 03-26-2014 01:52 AM
Great ???’s. after sanding the finish off I realized that some of the contact cement had eased its way thru the burl-definitely going back to cold press glue!! I sanded thru the veneer in a spot-there is now a shiny silver dollar inlayed in my wife’s new tabletop :-). Arm r seal was brand new, 1/64” veneer +/-, applied all thin coats w/ t-shirt. I appreciate all of the suggestions. The table top now has that “want to touch” look/feel & has that bar top depth of beauty to it after many, many hours of sincere patience.
