Dang! I Broke a Screw!
Forum topic by MT_Stringer posted 03-10-2014 03:29 AM 1660 views 0 times favorited 10 replies Add to Favorites Watch
View MT_Stringer's profile
MT_Stringer
3160 posts in 3194 days
03-10-2014 03:29 AM
Topic tags/keywords: tip maple drill press
I am in the process of building four base cabinets for a wet bar project.
I predrilled all of the holes for the Blumotion soft close hinges and had four of the six doors installed for test fit when it happened. A screw simply broke in two pieces just below the head!
That about ruined my day. After a fair amount of fussin’ and cussin’, I decided to make an attempt at removing it. I have several plug cutters but I couldn’t find the 1/4 incher. So, off to the big box store I went. I made it just in time before they closed the doors for today.
Armed with a new 1/4 inch plug cutter, I mounted it in the drill press and proceeded to cut the plug around the screw threads embedded in the hard maple door frame.
Then, I cut a 3/8” plug and glued it in the hole. Hopefully I will be back in business after a little touch up sanding tomorrow. the hinge will cover up the repair job. It will be good as new. I think when I pre-drill the hole again, I will make it a tad larger.
Dang it anyway.
10 replies so far
17936 posts in 1820 days
#1 posted 03-10-2014 04:02 AM
Cheap screws, not your fault. Nice fix though.
View Handtooler's profile
Handtooler
1541 posts in 2096 days
#2 posted 03-10-2014 05:24 AM
You’re certainly on top of the fix! Great save.
-- Russell Pitner Hixson, TN 37343 bassboy40@outlook.com
View jumbojack's profile
jumbojack
1674 posts in 2588 days
#3 posted 03-10-2014 05:38 AM
man that kind of thing just chaps my hide. Wax those screws. it does not matter what kind of wax, it all seems to work. Some use toilet rings, some paraffin. I use beeswax church candle stubs. I have dozens of them all over the shop. I use em on plane bottoms, for the miter bar on the table saw, on hand saw plates. Wax on wax off, no broken screws.
117061 posts in 3541 days
#4 posted 03-10-2014 05:52 AM
What a pain ,a pre drill and a little wax on the screws sometimes helps.
These can help too.
http://www.amazon.com/WoodRiver-Screw-Extractor-1-4/dp/B0032YWQ26/ref=sr_1_15?ie=UTF8&qid=1394430942&sr=8-15&keywords=screw+extractor
View Greg's profile
Greg
330 posts in 2837 days
#5 posted 03-10-2014 08:34 AM
A fine solution regardless. Nobody will ever know (Except us) just what a fine woodworker you really are!
-- You don't have a custom made heirloom fly fishing Net? http://www.Sierra-Nets.com
View Picklehead's profile
Picklehead
1041 posts in 1893 days
#6 posted 03-10-2014 11:42 AM
I’M TELLING!!!!!!!!!
That’s one of the things I like about this site. The next time I break a screw (or maybe some semi-unrelated disaster that this helps me with), I’ll have YOUR experience and ingenuity to draw from. Nice save!
-- You've got to be smarter than the tree.
View Roger's profile
Roger
20923 posts in 2767 days
#7 posted 03-10-2014 12:24 PM
Yep, pre-drill and wax. I keep an old cookie tin with a toilet wax ring for screwing. A little dad el do ya. Very nice fix tho. Good thinking.
View bigblockyeti's profile
bigblockyeti
5090 posts in 1684 days
#8 posted 03-10-2014 01:27 PM
I was pulling apart some old cabinet (not as old as I thought) and the screw holes for the hidden hinges were plastic inserts. I know this is becoming more common practice on mass production doors, but didn’t realize how long ago this had been done as these doors have to be close to 25 years old.
View madts's profile
madts
1855 posts in 2303 days
#9 posted 03-10-2014 01:29 PM
Nice save. Ditto the comment on the wax. Bar soap is also good. That way you can wash out your mouth after all the swearing you must have done :)
-- Thor and Odin are still the greatest of Gods.
MT_Stringer
#10 posted 03-10-2014 08:24 PM
Now for an update. I have made the repair and all is good to go. I am now back where I started about 12 hours ago. :-(
After a good night’s sleep, I masked off the area around the plug so I wouldn’t mess up the other parts of the frame.
Then I used my ROS with 80 grit pad and sanded the plug flush with the frame.
Yes, I broke out the soap. Irish Spring to the rescue! :-) And I drilled the pilot holes a little larger.
After reinstalling the hinge, there is no indication of the repair.
That makes me very happy. Ready for stain.
Thanks for all the replies. I hope this helps others that get in the same bind I was in.
Mike
