Hand Plane Jointer Fence - Shop Made
« back to Hand Tools forum
Forum topic by Jerry posted 03-09-2014 09:51 PM 4585 views 0 times favorited 31 replies Add to Favorites Watch
View Jerry's profile
Jerry
2658 posts in 1677 days
03-09-2014 09:51 PM
Topic tags/keywords: jig plane jointer joining
This is my shop made hand plane jointer fence. It’s made from 4 1/8” thicknesses of aluminum. What you see it attached to here is a Stanley No. 4, so the fence is 8 1/4” long. It’s held on the side of the plane with N-52 neodymium magnets, but I will be adding two more magnets to get a little extra holding power as it is just adequate right now. Also will be adding some UHMW slick tape over the part that runs along the side of the wood.
Updated pics with the additional magnets, and the slick tape
Attached to the No. 9 1/2 block plane
On 1/4” Spanish Cedar
-- There are good ships and there are wood ships, the ships that sail the sea, but the best ships are friendships and may they always be. http://www.geraldlhunsucker.com/
31 replies so far
View DocBailey's profile
DocBailey
584 posts in 2389 days
#1 posted 03-09-2014 10:38 PM
It’s certainly nicely executed, but are you really jointing with a no. 4?
Jerry
#2 posted 03-09-2014 11:36 PM
DocBailey: I used the name jointer fence because that is the popular name for this device in the tool catalogs, if it helps you, you can just call it a fence. This what I joint with…
DocBailey
#3 posted 03-10-2014 12:09 AM
OK – that’s good
But I guess my question is why a fence at all for a plane made to smooth panels?
View TheGermanJoiner's profile
TheGermanJoiner
847 posts in 1666 days
#4 posted 03-10-2014 01:09 AM
That’s a pretty sweet idea. Nice execution on that. I love working with metal too
-- Greg - Ferdinand and Son Construction: Do it right the first time. Like us on Facebook
Jerry
#5 posted 03-10-2014 01:11 AM
RE: Vertigo, Thanks! It was a lot of work and frustration getting it right, but it works very well, like a portable shooting board. I love your drill press setup, very impressive.
View theoldfart's profile
theoldfart
9747 posts in 2480 days
#6 posted 03-10-2014 01:18 AM
Gonna ask the same question, why a fence on a #4. I use a fence on a 6,7,8 to join
A 4 and 4 1/2 are intended primarily as smoothers, as a joiner they would not do the job since the sole is short.
-- "With every tool obtained, there is another that is needed" DonW ( Kevin )
View Ray's profile
Ray
126 posts in 2032 days
#7 posted 03-10-2014 01:54 AM
I used a fence on my #4 for a long time. It worked great on small stock where the #7 seemed awkward.
I now have a good shooting board that can take care of most of my small squaring needs.
Jerry, thanks for sharing your craftsmanship and ideas.
Let’s keep learning from each other.
-- Creating less fire wood every day
TheGermanJoiner
#8 posted 03-10-2014 02:06 AM
Couldn’t of said it better ray. We all do different things and adapt our tools to fit specific needs. Whether we would use it on a #4 or not, you have to admire the craftsmanship and ingenuity. I’ll say it again good job jerry
Jerry
#9 posted 03-10-2014 02:20 AM
RE: TheOldFart; Gonna ask the same question, why a fence on a #4. I use a fence on a 6,7,8 to join . A 4 and 4 1/2 are intended primarily as smoothers, as a joiner they would not do the job since the sole is short.
Because I’m making very small boxes, and it’s really hard to get the edges square without something like this, and for a box that is only 9×13 and made from half inch thick wood, the No. 4 is perfect for jointing the edges using this fence. I use this fence on my small block plane also, and believe me when I tell you that it works, and very well.
I will eventually make a good shooting board to replace the crappy one I have, but I doubt that it will be as flexible is this fence.
Now maybe I could use my 24” long No. 8 Jointer plane on a 13” long half inch thick piece of wood, but it seems a little ridiculous to me to even attempt it.
I don’t understand why you are having such a hard time accepting the usefulness of this fence, Lee Valley Tools sells them
, hell, they MAKE them, so is it such a stretch that other people have found them useful?
Jerry
#10 posted 03-10-2014 02:32 AM
Ray and Vertigo, thank you guys so much for your kind words and your support. It means a lot to me.
TheGermanJoiner
#11 posted 03-10-2014 02:35 AM
Jou got it meng
View Ray's profile
Ray
#12 posted 03-10-2014 02:38 AM
I need to apologize to Jerry. I sent the PM. It was in support of him and I completely understand his reaction to the Subject line.
I should have put a little more thought into my message, given what I perceive as an unnecessary situation. His response on this forum is completely my fault, not Jerry’s.
TheGermanJoiner
#13 posted 03-10-2014 02:49 AM
I’m confused. That’s actually pretty easy usually lol. But still confused
Jerry
#14 posted 03-10-2014 02:55 AM
Vertigo, I’m sending you a PM to explain, Ray, I removed the reference, not your fault, but thank you anyway!!!!
View Tim's profile
Tim
3812 posts in 1990 days
#15 posted 03-10-2014 02:56 AM
Jerry you did a nice job with it and Doc said so. Then you pretty much jumped down his throat when he asked why you used it on a #4. You could have just given the answer you gave Kevin, but instead you made it personal. We’re all here to learn and have fun. No need for that.
showing 1 through 15 of 31 replies
