Sanding Dimensional Lumber
Forum topic by Matt in Franklin posted 03-09-2014 09:18 PM 1742 views 0 times favorited 4 replies Add to Favorites Watch
View Matt in Franklin's profile
Matt in Franklin
294 posts in 1519 days
03-09-2014 09:18 PM
I am building a coffee table out of dimensional lumber (spruce/pine/fir). My plan is to use a general finishes gel stain on it (after using some blotch control conditioner) and arm-r-seal.
My question is how much sanding do I need to do on the lumber?
I have already sanded all the parts to 120. The remaining grits I have in my stock are 150 and 220.
-- Follow me on instagram and facebook @mwawoodworks , http://instagram.com/mwawoodworks/, https://www.facebook.com/MWAWoodworks
View hoosier0311's profile
hoosier0311
706 posts in 1932 days
#1 posted 03-09-2014 10:01 PM
I think you will get a wide range of answers to this. I certainly wont pretend to be any “authority” on things, but I’ll tell you what I do. Generally I start with 100 or 120, then to 150, and 220 is as fine as I go on nearly anything prefinish. granfather always said a little elbow grease on the sanding will make all the difference in the end result. I agree the blotch control is a good idea, then use the stain, this is where I use finer stuff 320 and 400 between coats.
If you search this site for sanding techniques there is alot of infor to be had.
-- atta boy Clarence!
View AlaskaGuy's profile
AlaskaGuy
3912 posts in 2215 days
#2 posted 03-09-2014 10:20 PM
For a stain and film finish it’s rare that I go past 150.
Matt in Franklin
#3 posted 03-09-2014 10:31 PM
AlaskaGuy, when do you go above 150? Tung oil? Varnish on bare wood?
View Texcaster's profile
Texcaster
1271 posts in 1580 days
#4 posted 03-09-2014 11:25 PM
Closed grain like maple and pine need careful sanding to remove all sanding marks. Open grain, ring porous, like Oak can be over sanded, and you can get high and low areas. Bare timber I stop at 240. Closed grain, hard timber fingerboards without much polish, 400.
-- Mama calls me Texcaster but my real name is Mr. Earl.
