Need help choosing a table saw
Forum topic by jasont posted 03-09-2014 04:43 AM 2168 views 0 times favorited 11 replies Add to Favorites Watch
View jasont's profile
jasont
10 posts in 1624 days
03-09-2014 04:43 AM
Topic tags/keywords: httplumberjockscomfirst_topicsnewhttplumberjockscomfirst_topicsnew
Hey everyone!
I am new to lumberjocks, long time reader first time poster. I live up in ontario and am looking to set up my own shop and am looking for a decent table saw that is reliable and wont blow out on me after a few uses. I am looking for something preferably mobile with accurate cuts. I am not a cabinet maker and dont require something that is accurate to mm but i want consistent cuts. I am more of a hobbiest/ DIY kinda guy
I have been looking into the ridgid cast iron table saw https://www.ridgid.com/ca/en/10-inch-cast-iron-table-saw
and
A more portable worksite saw like the bosch GTS1031 and build a mobile cabinet/ table around it with a router attachment.
Can anyone help me out here i keep hearing mixed reviews from different people on both saws. As soon as one sounds great a bad review pops up. The Rigid is at the limit of my budget so it anyone has any suggestions please let me know. Any and all are welcome.
Cheers
11 replies so far
View TheGermanJoiner's profile
TheGermanJoiner
847 posts in 1721 days
#1 posted 03-09-2014 05:00 AM
As a contractor I have quite a bit of experience with portable tablesaws. I can’t speak for the cast iron ridgid saw. I do however have the portable ridgid on the mobile base. It has a 15 amp motor and I think it’s a great saw. In my shop I have a 3 hp unisaw which is great. But for the money I think ridgid makes a great product. With the cast iron table unit I would imagine you get a better fence system but maybe other ljs can weigh in on that. If the fence is good on that ridgid and you don’t plan on moving it to job sites, I think it’s a nice option. If you go portable though I would recommend the ridgid over the bosch. It can rip a full 4×4 in one pass. The bosch can’t. Don’t get to wrapped up in reviews. There’s always gonna be someone with a bad experience. Good luck on your decision
-- Greg - Ferdinand and Son Construction: Do it right the first time. Like us on Facebook
View NiteWalker's profile
NiteWalker
2737 posts in 2660 days
#2 posted 03-09-2014 05:07 AM
I’d avoid both.
The ridgid has a well known alignment problem where blade to miter slot alignment changes when raising or lowering the blade. That saw needs a recall.
The bosch is a jobsite saw, and I have the 4100, and built a base for it like you mentioned. I could only use it for a few months before I got fed up with the small table size, fence that won’t lock parallel to the blade reliably, table warping when the motor warms up from use, etc. It’s just not a good saw for anything other than jobsite use. I gave mine to my pop and have a nice steel city hybrid with cabinet mounted trunnions arriving next week.
I’d buy the best you can afford. As for mobility, any saw can be mobile with a mobile base.
View woodworkingdrew's profile
woodworkingdrew
190 posts in 1692 days
#3 posted 03-09-2014 05:10 AM
Jason- I was in your shoes 6 months ago. I went to home depot and lowes multiple times looking at portable saws vs contractor saws. The general thought is, purchase a portable job site saw if your going to be mobile and working “on the job.” The stationary contractor saws have the following advantages:
- heavy, solid cast iron top
- better fence
- more accurate cuts
- quieter operation
For the home DIY, hobbiest, or professional woodworker, look for a contractor or unisaw. The direct drive saws are good don’t get me wrong, but for ripping 4×8 sheets of plywood its going to be tough. I have the ridgid 3250. Solid saw and have been completely satisfied with it. DO your homework and research the major differences. The table saw by far is a huge key to any woodworking project.
-- Andrew, California
View lepelerin's profile
lepelerin
495 posts in 2408 days
#4 posted 03-09-2014 07:36 AM
I do have a Ridgid 4512 saw. Once well tune this saw is fantastic. I am a hobbyist, not in a production environment.
The fence problem can easily be fixed.
The blade alignment is something I do not have on my machine. I always lock the lock height know and the blade is dead on.
If I angle the blade I do the same and I do not have that problem.
I regularly check with a dial indicator and in the worst case scenario I do have 1-2 th of misalignment.
IMHO this is a good saw for the price.
View knotscott's profile
knotscott
8100 posts in 3459 days
#5 posted 03-09-2014 11:57 AM
Are you in Ontario, Canada or Ontario California? If you’re in Canada, I’d check out the Craftex CT-146 ...it’s essentially the same saw as the former Ridgid TS3650 (minus the Herculift). You give up the inboard motor and modern riving knife, but gain solid cast wings, better fence with more rip capacity, and a much better reputation.
As mentioned, buy a portable saw for portability, not price. A stationary saw has several advantages.
jasont
#6 posted 03-09-2014 02:53 PM
ontario canada knotscott. Thanks for the suggestion i will be checking that one out for sure.
View Rayne's profile
Rayne
972 posts in 1623 days
#7 posted 03-09-2014 03:19 PM
First time poster and visitor here. I’ve always heard about this place, but never came to visit. Anyways, I actually just bought my Table saw yesterday from “Blue” store. I did the research on the Ridgid 4512 and have to agree that you should really know what you’re getting into if you pick that saw. If price is a concern, I was able to get the Delta table saw from “Blue” with a 25% off coupon from HF, if you’re familiar with them. Each store is different, but it’s a consideration if you have those stores in Canada that could save you a bunch if the store is willing. My 2 cents worth. :)
jasont
#8 posted 03-09-2014 03:22 PM
thanks. Unfortunately we dont have HF up here or Blue(never heard of that one. But thanks for the post :)
117166 posts in 3660 days
#9 posted 03-09-2014 03:48 PM
Welcometo Ljs
I had always recommended the Ridgid 4512 but after finding out about the blade alignment problem I would tell my students about the 4512 but warned them of the possibility of the blade alignment problem. Now there seems to a 4512 out there that the alignment problem has been solved. Since Knottscott is our resident table saw expert among other tools . I would strongly urge you to pay attention to his advise.
There must be a hundred threads one Ljs now about which table saw to buy,you might do a search on Ljs and read through all of those post to gain even more info.
View bluestyle11's profile
bluestyle11
3 posts in 2123 days
#10 posted 03-09-2014 03:59 PM
knotscott, I never realized the Craftex was a clone of the Ridgid 3650. Actually, I never heard of it. I have the 3650, and once tuned and dialed in, it is a fantastic table saw. Although it does not have the riving knife, you can make zero clearance inserts with a splitter attached.
I just added a cast iron router wing extension from General International with a Mast-R Lift II, and this saw is outstanding.
I strongly urge you to check out the Craftex, you can always get a used Herc-u-Lift for it.
Jimmy
View toolie's profile
toolie
2138 posts in 2712 days
#11 posted 03-09-2014 08:11 PM
Herc-u-lifts are no longer produced by ridgid, except when part of a TS purchase( like on a 3650 or 4511). I have one I found on CL and I’ m holding on to it for the future. I don’t believe they are readily available.
