Tongue and groove without specialized planes
« back to Hand Tools forum
Forum topic by Ray posted 03-09-2014 02:57 AM 5909 views 0 times favorited 15 replies Add to Favorites Watch
View Ray's profile
Ray
126 posts in 1972 days
03-09-2014 02:57 AM
Is it practical/feasible to create tongue and groove joints without specialized planes? If so, what would be the process?
Thanks
-- Creating less fire wood every day
15 replies so far
View WayneC's profile
WayneC
13753 posts in 4067 days
#1 posted 03-09-2014 03:00 AM
There are router bit sets that would allow you to cut them if you have a router/router table…
View TraylorPark's profile
TraylorPark
212 posts in 1568 days
#2 posted 03-09-2014 03:02 AM
I use a router bit set to make all my tongue and groove, but I suppose you could do it by table saw kerfs and a rabbit plane. Don’t know though I’ve never tried.
-- --Zach
WayneC
#3 posted 03-09-2014 03:02 AM
http://www.rockler.com/search/go?asug=&w=tongue+groove+router+bits
WayneC
#4 posted 03-09-2014 03:03 AM
Most of the bit sets look like they cost as much as a plane. :)
View Ray's profile
Ray
#5 posted 03-09-2014 03:03 AM
I should have been more precise – alternative method using hand tools.
WayneC
#6 posted 03-09-2014 03:04 AM
View waho6o9's profile
waho6o9
8168 posts in 2546 days
#7 posted 03-09-2014 03:06 AM
http://www.lie-nielsen.com/joinery-planes/tongue-and-groove-planes/
It seems to be more efficient to use the Lie Nielsen plane than trying
to figure out another way, so I’d say no to your question.
10283 posts in 3617 days
#8 posted 03-09-2014 03:13 AM
You can use a cutting gauge and chisel.
View thedude50's profile
thedude50
3603 posts in 2447 days
#9 posted 03-09-2014 04:16 AM
I make mine with a 45 its a great tool and easy to set up and use you can get one cheel and it does 45 tasks it has no soul according to Roy Underhill but it works like a dream
-- Please check out my new stores http://woodratnest.com and http://woodshopstore.com
View Don W's profile
Don W
18686 posts in 2537 days
#10 posted 03-09-2014 03:29 PM
I suppose you could use a dado for the groove side and any kind of grooving plane for the groove.
Edit: Making your own matched set of T&G wouldn’t be that difficult.
View Tim's profile
Tim
3785 posts in 1931 days
#11 posted 03-09-2014 06:42 PM
Technically it’s just a dado on the groove side and two rabbets on the tongue side so you could do it with a marking gauge and a chisel if you were so inclined. But that’s slow and tedious enough to make the specialized planes worth it. It’s challenging to be precise enough on the narrow edge of a board.
I agree making them wouldn’t be impossible. Or buy a set of wooden tongue and groove planes. They can be reasonable. If you really want to be cheap, buy a set without blades and make your own.
Other options are a plow plane of any kind including wooden to cut the groove and a rabbet plane to cut the tongue, a 45 combination plane used either just as a plow or with the tongue blade, or a router plane could be made to work if you clamp up some guide boards to support it on the edge of the board.
View 12strings's profile
12strings
434 posts in 2354 days
#12 posted 03-09-2014 07:03 PM
Hand tool only methods, in order of easy to difficult:
-t&g plane, combination plane, or the like,
-marking guage, router plane for the groove, rabbet plane for both sides of the tongue.
-clamp a staightedge and hand saw your lines, the clean out the waste with a chisel.
-chisel out the whole thing like a giant mortise. (I wouldn’t do this unless you have no handsaws, in which case you may want to either get one, or reevaluate your hobby choice.)
I have done the saw and chisel thing a few times on small things like a bridal joint, but even there its not much fun.
If you go to power, you can use a cheap 1/4 in. Router bit to make grooves, and any straight bit to make tongues…
-- I'm strictly hand-tool only...unless the power tool is faster and easier!
View mikeevens45's profile
mikeevens45
68 posts in 1545 days
#13 posted 03-09-2014 08:25 PM
if you are going to do a couple you can get the harbor freight bits for about 20 bucks..if you are gonna do a lot get a set of freud or rockler etc. you can use a 1/4 straight for the groove and a 3/4 straight for the rabbits on the edge…best to use a router table…are u using these for panel making…(gluing board edges to make a wider board?)..if that’s the case I would edge glue or bisquit join em or you can even use a rail and stile set if you have one…I guess it depends on your project…they make edge glue sets for joining boards and I used the rail and stile set in a pinch and was actually surprised with the results. chisels are harder work and you should be proficient with them to avoid a bad mate on the pieces…if I did it with chisels I would make a very nice board for the scrap bin…but it is a good learning project
good luck and may the woodworker in you shine
-- as technology progresses, wood workers seem to regress...all my power tools and my favorite is a chisel and a hand plane
View bandit571's profile
bandit571
19767 posts in 2653 days
#14 posted 03-09-2014 08:32 PM
Seems I have made a few recently. Router with a straight cutting bit for the groove, and a #78 Rebate plane for the tongues
Of course, one could even pick up a simple rabbetting bit.
I centered the router ( edge guide was installed) for the center of the edge of the board, as well
Have to watch how you run the router along the edge, to prevent it from blowing out a side.
Short grooves? Two saw cuts to define the outside of the groove. Then just chisel out the inner waste. Not too bad if they are shorter than the saw.
waho6o9
#15 posted 03-09-2014 08:42 PM
