Power Twist Plus V-Belts
Forum topic by OldWrangler posted 03-08-2014 07:52 PM 807 views 0 times favorited 1 reply Add to Favorites Watch
View OldWrangler's profile
OldWrangler
731 posts in 1590 days
03-08-2014 07:52 PM
Topic tags/keywords: tip
Just thought I’d put in my 2 cents worth about a product that is really worth considering. For several month my old Rockwell Table Saw has been vibrating badly. I have asked about it on this forum and gotten some good answers but nothing really helped that much. When I say vibrating I mean tools or wood on the out table rattling and bouncing on the floor. It has gotten more annoying every time I use it. I tried aligning the pulleys, checking the pulley for wobble, checked bearings and even put on a new V-belt. Nothing made any improvement.
For years I have heard how the Link Belt will stop the vibration but at $40, I considered this too expensive to try. Well, not so. Yesterday I shelled out $40 at Woodcraft for the one they carry. Put it on this morning and wow, I’ve got a new saw. This belt did every thing it said it would and more. And a nice feature is that it links together so would be good for replacing a belt on a captive pulley., no need to dismantle the drive. The links take some work to link together but it’s not bad after you see how it has to go. Took me about 20 minutes to put together a belt just shorter than the original type belt.
The vibration is completely gone and the saw is only about 30% as noisy. And it seems to cut better. This is one of those times when a product lives up to it hype. This is the best thing since Viagra. I can go on record that this is a really great product. If it will last the 10 years I was told it would I will be even more impressed.
I heartily recommend this belt for calming down a table saw. I wish I had spent the money years ago. AND ONE OF THE BEST THINGS ABOUT THIS BELT, IT IS MADE IN USA.
-- I am going to go stand outside so if anyone asks about me, tell them I'M OUTSTANDING!
1 reply so far
View rayman54's profile
rayman54
15 posts in 1546 days
#1 posted 03-08-2014 08:14 PM
The cheap die-cast pulleys they put on table saws and other equipment are not balanced and this is one point where the vibration starts. My first Craftsman TS came with die-cast pulleys and the belt was very poor in construction as well, (more cause of vibration). All of this vibrating leads up to set screws coming loose on the pulleys causing more problems like wear on blade arbor and even worse the vibration is very hard on the blade arbor bearings, I had to change one.
I put the machined shives and link belt on that saw about 20 years ago and it still is running great, like a new saw with them.
not JMHO,, a proven fact
