Shooting ramp board
« back to Hand Tools forum
Forum topic by JohnChung posted 03-08-2014 01:03 PM 1442 views 1 time favorited 4 replies Add to Favorites Watch
View JohnChung's profile
JohnChung
407 posts in 2036 days
03-08-2014 01:03 PM
Hi,
I have finally completed the 5 degrees ramp based on Derek Cohen design. It now takes shavings on end grain beautifully. Not much effort itself. But I do then to force the blade through at times. That is due to my silly mindset of brute force. Overall it is a well worth built. Below are pictures. Thanks for Derek to the questions I had
The 5 degrees does make end grain shavings easy!
View Aj2's profile
Aj2
1352 posts in 1760 days
#1 posted 03-09-2014 04:14 AM
Looks good John,I hope it holds it shape for many years.The ones I have made from solid wood always seem to get wonky and I just end up throwing the out.
What kind of wood did you use,Kinda looks like afromosia.
-- Aj
JohnChung
#2 posted 03-09-2014 08:04 AM
Thanks Aj2. It is resak a local Malaysian hardwood the ramp itself. Here are some data on the wood itself.
http://www.fpl.fs.fed.us/documnts/TechSheets/Chudnoff/SEAsian_Oceanic/new_pdf_files/Cotylelobiumspp.pdf
http://www.asianplant.net/Dipterocarpaceae/Vatica_rassak.htm
http://woodwizard.my/report.asp?ItemID=102
I did check up on afromosia. The end grain for resak looks exactly like afromosia
http://www.wood-database.com/lumber-identification/hardwoods/afrormosia/
The board is kayu manis while the fence is meranti. Both pretty soft. For insurance the board fence at the bottom is also resak.
View bobasaurus's profile
bobasaurus
3400 posts in 3146 days
#3 posted 03-09-2014 08:18 AM
Looks great. I want to build a slanted version for my shooting plane someday to reduce wear and make that nice shear cutting action.
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
JohnChung
#4 posted 03-09-2014 08:25 AM
The 5 degrees really helps to reduce the shearing action. I highly recommend it.
