Full blind hand cut dovetails, why?
Forum topic by TopamaxSurvivor posted 03-08-2014 07:26 AM 19941 views 0 times favorited 32 replies Add to Favorites Watch
TopamaxSurvivor
18249 posts in 3645 days
03-08-2014 07:26 AM
Topic tags/keywords: dovetails full blind hand cut
I just received this advice in my inbox: its time to try full blind dovetails. Why? If I hand cut dovetails I want to be able to see and admire them! What do you say?
32 replies so far
View Dallas's profile
Dallas
3599 posts in 2456 days
#1 posted 03-08-2014 07:53 AM
Hmmmm, elegant joint but I’ve never seen one in campaign furniture. Most of what I’ve found is rabbeted, although it might actually have hidden DT’s, I don’t normally get to take it apart.
View grizzman's profile
grizzman
7836 posts in 3272 days
#2 posted 03-08-2014 02:16 PM
im with you bob, if im going to hand cut them, i want to see them, i cant imagine doing all that work to not see them, nope, there going to be seen…
-- GRIZZMAN ...[''''']
View Don W's profile
Don W
18686 posts in 2536 days
#3 posted 03-08-2014 02:19 PM
Although I agree 110%, I guess there are times when it just doesn’t fit the style. Remember the DT is one of the strongest joints you can make, so there was a day when it was more about function then presentation.
HillbillyShooter
5811 posts in 2261 days
#4 posted 03-08-2014 02:25 PM
I agree with Don W—function over presentation in a time before biscuits and dominos.
View 12strings's profile
12strings
434 posts in 2353 days
#5 posted 03-08-2014 02:50 PM
Yep, It’s a good joint because it (1) has the strength of dovetails (stronger than biscuits), and (2) is hidden. I chest made this way would last hundreds of years if done well.
-- I'm strictly hand-tool only...unless the power tool is faster and easier!
View shipwright's profile
shipwright
7967 posts in 2767 days
#6 posted 03-08-2014 02:59 PM
I used full blind dovetails in a recent project (blog here) but they were a little different than these. I understood that the intent was to have the structural strength of a dovetail without any end grain showing to telegraph through a veneered surface.
The way I did them, they appear to be a mitered corner rather than a lap joint. Mine, however gave the illusion away when you looked at the ends (top and bottom) of the joint.
Patrick Edwards corrected me in a comment telling me that the last pin on each end should be mitered to complete the illusion of a mitered joint. His blog is much better than mine.
You can find his blog on them here
View stefang's profile
stefang
15881 posts in 3303 days
#7 posted 03-13-2014 11:45 AM
Good question Bob. My only reason would be just to cut them as a challenge. I have found through experience that glued miter joints are more than sufficient for a small box unless it is expected to get some very abusive handling. A miter cut is after all part side grain and part end grain, so it holds a lot better than many think. Blind or half blind dovetails were used in the past for furniture case goods which were heavy and needed a strong but invisible joint as visible joinery is not always a good attribute on some designs.
View iminmyshop's profile
iminmyshop
284 posts in 1963 days
#8 posted 03-13-2014 12:20 PM
There are many ways to put joints together including miters. Most of the support given is more than adequate. Most fine furniture is over-engineered. So while it is true that there is terrific strength in hidden dovetails, an L shaped laminated spline would also give a ton of strength, be lots easier to make while still remaining hidden and be lots easier to do. In short, I agree that if I am going to all that trouble, I literally want something to show for it. A quiet self-pat on the back just wouldn’t do it for me.
-- http://www.alansfinewoodworking.com/
View Don Butler's profile
Don Butler
1092 posts in 3364 days
#9 posted 03-13-2014 03:05 PM
Mike, pardon my ignorance, but I have always regarded the miter joint to be 100 percent end grain.
Please educate me. How does the miter cut reveal any side grain?
Don
-- No trees were damaged in posting this message, but thousands of electrons were seriously inconvenienced.
Smitty_Cabinetshop
15283 posts in 2587 days
#10 posted 03-13-2014 03:25 PM
Paul, that link to Mr. Edwards does indeed show what I considered a full-blind dovetail, or “A secret mitered dovetail joint”. What Mr. Schwarz is doing is a full-blind rabbeted dovetail per “The Complete Illustrated Guide to Joinery”
Good stuff in this post!
Would I do one? If the furniture style required, yes.
View bigblockyeti's profile
bigblockyeti
5101 posts in 1689 days
#11 posted 03-13-2014 03:40 PM
I would certainly want to see my work also if taking the time to hand cut.
View bondogaposis's profile
bondogaposis
4688 posts in 2320 days
#12 posted 03-13-2014 06:58 PM
I could definitely see using these for carcase construction. I think difference between visible dovetails and blind dovetails is like the difference between a mortise and tenon and a through mortise and tenon. The blind one is not seen so could be made faster with les concern for the visual aspects.
-- Bondo Gaposis
TopamaxSurvivor
#13 posted 03-14-2014 01:26 AM
Hmmmmmm! I did not know this discussion was happening. Just because you are getting notifications, doesn’t mean you are getting all of them. I guess I’m with Mike, started getting this one today.
Bondo Gaposis, Not as much pride of accomplishment and bragging rights in M&T as there is with DT ;-) at least IMO.
Is there a way to do full blind; either secret mitered dovetail or full-blind rabbeted with a machine? Seems to me the only way to do them is by hand.
View Loren's profile
10278 posts in 3617 days
#14 posted 03-14-2014 01:56 AM
Well, I wouldn’t do them unless I had a specific reason to do them
for structural or stylistic reasons. They look pretty easy to do
compared to making clean through dovetails by hand. Realistically
one can make quite a mess of them if they don’t show.
... I think with some ingenuity some power tool method could be
devised to remove a lot of the waste in these sorts of joints,
but establishing the final geometry would probably involve
hand work. I haven’t thought about it more than a little as
most woodworking clients would never care or care to know.
bondogaposis
#15 posted 03-14-2014 02:07 AM
Topamax, maybe my point wasn’t clear. When you make a normal M&T joint none of it is visible and it is fairly easy, but when you make a through M&T joint you have to be much more careful because the tenon and mortise is visible on one side. My thinking is that a full blind DT joint maybe a lot easier than a half blind as none of it is visible. I will have to make a few to know for sure.
-- Bondo Gaposis
showing 1 through 15 of 32 replies
