Best drill bit
Forum topic by MapleHead posted 03-07-2014 10:54 PM 1021 views 0 times favorited 7 replies Add to Favorites Watch
View MapleHead's profile
MapleHead
25 posts in 1507 days
03-07-2014 10:54 PM
Topic tags/keywords: drill bit question
I need to inlay some tiny clay markers into my guitar’s fretboard. The markers are small circles that are a 1/4” wide by .060” thick. What is the best drill bit to produce the tiny holes these will lay in? I’ll be using a drill press.
My concern with typical forester and brad point bits is that the points are too long and will drill into the truss rod cavity.
Any and all advice is greatly appreciated.
7 replies so far
View crank49's profile
crank49
4030 posts in 2933 days
#1 posted 03-07-2014 11:15 PM
You need a hole that is 1/4” dia by .060” deep, if I understand correctly?
I would be doing that with a router mounted in a special jig to hold everything fixed laterally.
Or with an end mill mounted in the drill press. Or a mill if you have access to one.
View Slemi's profile
Slemi
116 posts in 1503 days
#2 posted 03-07-2014 11:18 PM
If the area You are working on is flat, You can take router and some flat stock. Cut out some large hole and use router with guide to “drill” out the hole with router.
Sorry my native language is not english so I don’t know the exact terminology for tools.
MapleHead
#3 posted 03-07-2014 11:19 PM
Thanks Crank. The router version I might use on the next neck, but the current one would be too difficult.
Those end mill bits look pretty good. Now, do they come in 1/4”?
View Texcaster's profile
Texcaster
1273 posts in 1636 days
#4 posted 03-07-2014 11:33 PM
I use brad points. Fret markers, side dots, frets & and binding all fitted before gluing fb to the neck. I do final shaping of the neck after gluing on the fb. Clay dots have the best tone…....that’s what they say. ( smiley )
-- Mama calls me Texcaster but my real name is Mr. Earl.
MapleHead
#5 posted 03-07-2014 11:34 PM
Hi Tex
Do you use brad points for the side markers as well?
Texcaster
#6 posted 03-07-2014 11:46 PM
For side dots, just small bits. Hobby stores are a cheap emergency source for side dots.
View darthford's profile
darthford
567 posts in 1886 days
#7 posted 03-09-2014 04:09 PM
Suggest you discover center cutting end mills also three flute drill bits both from the metal machining world. They can be razor sharp be careful.
