Need Dado blade help!
Forum topic by Medickep posted 03-07-2014 06:09 PM 1193 views 0 times favorited 8 replies Add to Favorites Watch
View Medickep's profile
Medickep
569 posts in 1707 days
03-07-2014 06:09 PM
Topic tags/keywords: resource
I got this old Craftsmen Dado blade set from my father and I don’t believe it’s to blame as I’ve seen it work first hand and know people who use Harbor freight ones with success too!
My pattern seems to be to try a practice piece of wood with success and than when I need it to work get what you see in the picture. Total blow out of the plywood!! Does anyone have any suggestions on what’s causing this? I try to spread out the chippers as well as offset the teeth, so the identical ones aren’t side by side!
Thanks!!
-- Keith
8 replies so far
View mahdee's profile
mahdee
3874 posts in 1737 days
#1 posted 03-07-2014 06:15 PM
If you use a utility knife and mark the cuts going all the way down past first veneer, it should give you a better result. Suffice to say sharp blades are essential. It doesn’t look like it is caused by wobbly dado.
-- earthartandfoods.com
View Julian's profile
Julian
1308 posts in 2660 days
#2 posted 03-07-2014 06:17 PM
Have you installed a zero clearance insert plate on your table saw just for the dado blades? That should help. But in my opinion; the Craftsman dado blade is junk compared to others. I purchased a dado set at Rockler with their 20% coupon a few years ago (under $100) and it made a huge difference. Don’t remember the brand. You get what you pay for.
-- Julian
View Monte Pittman's profile
Monte Pittman
28968 posts in 2307 days
#3 posted 03-07-2014 06:23 PM
+1 for Julian. The better the dado set, the better cuts they make. I have tried using cheap sets and got really poor results.
-- Mother Nature created it, I just assemble it.
Medickep
#4 posted 03-07-2014 06:28 PM
I don’t have a zero clearance for it, just the stock rigid one. Wouldn’t I need a zero for each width? It good just be cheap and dull like suggested. Just weird that it’s not consistent.
-- Keith
View bigblockyeti's profile
bigblockyeti
5106 posts in 1690 days
#5 posted 03-07-2014 06:37 PM
Sharp blades are key, especially for the side cutters, one of which looked like it got a little hot!
View AnonymousRequest's profile
AnonymousRequest
861 posts in 1518 days
#6 posted 03-07-2014 06:43 PM
Sharpness/quality like others said. I got an ‘ole craftsman wobble dado that cuts cleaner.
View knotscott's profile (online now)
knotscott
7985 posts in 3345 days
#7 posted 03-07-2014 10:39 PM
I can certainly understand the sentimental value of that set, but the proof is in the pudding….that ply can be tough to tame, but that’s a horrible cut. At the very least clean it up, and see if you can good techniques for sharpening a steel saw blade with a file. Add a higher quality dado set to your wish list….
View bandit571's profile
bandit571
19765 posts in 2653 days
#8 posted 03-07-2014 10:45 PM
Been using THAT set for a few DECADES, no problems like that. Might just need a sharpening??
Zero clearence inserts do help, though.
Been setting mine uo on the arbor, so that the teeth on the outside cutters match the wat the face out. Won’t worl too well in the both lean out to the sides at the same time. Might also take just a bit of the set off the teeth…
Same set that Vermont American put out, just VA had more cutters.
