Switching table saw to 240v.
Forum topic by JayTay posted 03-05-2014 02:22 AM 1617 views 0 times favorited 16 replies Add to Favorites Watch
View JayTay's profile
JayTay
15 posts in 1510 days
03-05-2014 02:22 AM
hello,
i got to change my saw over to 240. i turn that baby on and the lights dim….no good. i have a craftsman model 152.221040. the problem is from the switch to the motor there is another plug. it’s a 110 style plug. the manual says nothing about this plug just to change the on on the end of the cord coming out of the wall. is it safe to leave is as is and just do the conversion? thanks for any help.
16 replies so far
TopamaxSurvivor
18247 posts in 3641 days
#1 posted 03-05-2014 02:36 AM
You need a proper outlet and plug to fit it. 240 will not be friendly to your other 120 volt equipment!
View bigblockyeti's profile
bigblockyeti
5093 posts in 1686 days
#2 posted 03-05-2014 02:37 AM
To leave it you would have to have a 120V outlet that was actually putting out 240V. It will work, but is very bad practice due to the fact that you now have a 120V outlet (even though it’s on your saw) that has a 240V potential. While it is very unlikely that anything else would be plugged into the outlet on the switch, the fact that it could be would be reason enough for me to change both plugs instead of just the one going into the wall.
View CharlesA's profile
CharlesA
3312 posts in 1763 days
#3 posted 03-05-2014 02:40 AM
Perhaps I read the OP wrong, but it sounds like he did change the plug on the saw that goes to the outlet, but there is a second 110 style plug that goes from the switch to the motor, right?
TopamaxSurvivor
#4 posted 03-05-2014 02:45 AM
Thanks CharlesA, I misread. You are correct. I am not sure what the proper answer is. It has to do with what the manufacturer’s intentions and what instructions say. It is not a code issue as it is not part of the building wiring or a motor protection issue.
JayTay
#5 posted 03-05-2014 02:48 AM
yes you are right CharlesA. from the wall to the switch is a NEW 240 plug and cord. but from the switch to the motor is ANOTHER 110 type plug in that cord. you can unplug the motor from the switch. i dont know why you would do that though.
what i want to know is will that plug handle the load if switched to 240v or should i just change it over too.
View sawdustjunkie's profile
sawdustjunkie
382 posts in 1683 days
#6 posted 03-05-2014 02:50 AM
I have a Craftsman 113 model and to run it on 220, you have to switch over some wires on the motor and then change the plug that goes into the wall and also have a 220 outlet wired for 220.
Otherwise you will have major problems and probably burn something up.
-- Steve: Franklin, WI
bigblockyeti
#7 posted 03-05-2014 03:05 AM
The plug and outlet on the saw will certainly handle the current load as it will be in theory exactly half of what it was at 120V. The cord will probably handle it (especially since the motor can be switched to 240V), but I would still check to see what is imprinted on the jacket.
View MrUnix's profile
MrUnix
6592 posts in 2164 days
#8 posted 03-05-2014 03:43 AM
The intermediate plug (from switch to motor) should not need to be changed.. The only thing you should have to do is (1) change the wiring in the junction box on the motor to switch from 120 to 240v and then (2) change the plug end to fit in your 240v wall outlet (from switch to wall). Motor wiring diagram should be on the inside of the junction box cover and indicate how to wire for 120/240v operation.
JayTay
#9 posted 03-05-2014 03:56 AM
thanks for the help guys. im going to give it a go. i’ll watch the temp on the inside plug after some use.
View Madbeez's profile
Madbeez
6 posts in 416 days
#10 posted 03-03-2017 01:19 AM
I know this is a real old post but I have the same craftsman saw. I need the diagram to switch the motor back to 110. Was hoping jaytay was still around.It hummed at 220 and is probably the best home shop tool/saw I’ve ever purchased. This saw is a classic and the craftsman on it doesn’t speak to its quality and dependability.
View knotscott's profile
knotscott
7980 posts in 3341 days
#11 posted 03-03-2017 01:40 AM
The diagram should be on the inside of the cover of the wire junction box on the motor.
MrUnix
#12 posted 03-03-2017 02:01 AM
- knotscott
.... or on the motors data plate.
JayTay
#13 posted 03-03-2017 02:07 AM
Here it is bud! Let me know if you need anything else.
View Jesden's profile
Jesden
20 posts in 434 days
#14 posted 03-03-2017 04:25 AM
I just had this same issue. I put a 110 plug on wall first thinking 220 would be fine and the plug was cheaper than a 220 plug. It did not work. First time I plugged in the saw cord (which was new also) I saw archs and it burnt the plug. Researching I found out the plug just did not handle it and the saw never turned on either. I went back and changed out the cord and the plug and saw ran like a dream.
-- What you get by achieving your goals is not as important as what you become by achieving your goals.
View toolie's profile
toolie
2120 posts in 2594 days
#15 posted 03-03-2017 11:36 AM
Wire the motor as indicated on the pic above. Already changed the plug and receptacle on the wall to 220. The plug between the switch and the motor are pass-throughs only and should not present a problem as 220 needs two conductors and a ground and that’s what’s present in the pass-through plugs
