tablesaw mounted router table
Forum topic by ssomzzz posted 03-05-2014 02:07 AM 859 views 0 times favorited 6 replies Add to Favorites Watch
View ssomzzz's profile
ssomzzz
3 posts in 1564 days
03-05-2014 02:07 AM
Hello, I hope I hope I can get some good advice. Question I glued (2) 1/2” sheets of corian then onto 3/4” birch ply what router plate do you recommend? Also price is important and ease of install, not a pro yet but workin on it
also the fence I’m using can be seen at finewoodworking .com. Under tablesaw mounted router table
View knotscott's profile
knotscott
8017 posts in 3376 days
#1 posted 03-05-2014 02:22 AM
You want something strong….metal or phenolic are good. I’ve got one from Hartville tool that’s been great.
http://www.hartvilletool.com/product/4990/router-tables-and-accessories
ssomzzz
#2 posted 03-05-2014 12:56 PM
Thank you ,I will consider that. I’m just concerned about routing the corian,
View The Box Whisperer's profile
The Box Whisperer
678 posts in 2071 days
#3 posted 03-05-2014 01:00 PM
I like the veritas ones. They have a steel one that amazing, and pricey, and a phenolic one thats pretty nice and more affordable. I have the phenolic mounted in my TS wing. I also have their steel top and cant say enough good things about it. Lee Valley will even replace the phenolic insert if you mess up the drilling.
-- "despite you best efforts and your confidence that your smarter and faster than a saw blade at 10k rpm…. your not …." - Charles Neil
View NiteWalker's profile
NiteWalker
2737 posts in 2577 days
#4 posted 03-05-2014 09:36 PM
IMHO, the incra magnalock router plates are the best in the business.
Pricey, but you’d only need one for a very long time, and it would hold its resale value.
It has features that put it above the rest. The inserts are held in with rare earth magnets and you can change them out without tools. They’re also adjustable for level. Others you have to use tape or trust the manufacturer.
That said, I prefer a plateless, seamless top. Nothing but a hole for the router bit and countersunk screw holes.
Corian routs easily. It’s just plastic.
ssomzzz
#5 posted 03-05-2014 10:19 PM
Thank you
View keninblaine's profile
keninblaine
130 posts in 1602 days
#6 posted 03-06-2014 05:52 PM
I picked up a Kreg unit with adjustable support brackets that allow you to adjust each of the 4 corners to be perfectly flush with the table surface. It also avoids having to rout the top since the brackets support the insert.
-- Ken, Blaine Washington
