inlay cutting
Forum topic by BubingaBill posted 03-04-2014 08:37 PM 1130 views 0 times favorited 9 replies Add to Favorites Watch
View BubingaBill's profile
BubingaBill
295 posts in 1770 days
03-04-2014 08:37 PM
Topic tags/keywords: jig question
Hi guys,
I received a small stick of Mother of Pearl and I was wondering if someone has a jig for cutting this either on a scroll saw or a band saw?
I know I can cut slices but I was thinking of cutting 3/8” circles to add dots to a case lid. I have never worked with this material before so I am not sure how to go about it. I don’t know if it is real or synthetic. I’m guessing synthetic.
I looked on YouTube and they only cover freehand designs for frett work.
I’m starting with a small block.
I am thinking I would cut slices a bit thicker then I need and then draw a circle on it and either go to the scroll saw or sanding station and slowly approach my line.
I am concerned my circles will come out all funky.
Any ideas?
-- Measure twice and try not to cut your thumbs off!
9 replies so far
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3798 days
#1 posted 03-27-2014 06:47 PM
What an interesting question. I’d thought mother of pearl only came in sheets, I learned something today. Woukd you have a picture? Hope you find an answer.
BubingaBill
#2 posted 03-27-2014 06:56 PM
Mark,
I will take a picture tonight and post it tomorrow. I have to spend the evening shutting down my wood shop to make room for my wife’s SUV. I have to replace the alternator tonight and it’s too cold to do that in the driveway!
I’m guessing the “stick” I have is some synthetic pearl.
View Jim Finn's profile
Jim Finn
2666 posts in 3008 days
#3 posted 03-28-2014 01:34 PM
I would try a plug cutter to make the circles. Machine it as though it was wood. Make the plug, drill the hole and glue the plug in place. I have never done this with anything but wood but that is what I would try.
-- No PHD just a DD214 and a GED Website> https://craftingcouple.com
View unbob's profile
unbob
810 posts in 1989 days
#4 posted 03-28-2014 03:56 PM
I have cut like material for a guitar repairman. The problem there being, the material must fit an existing hole. This is how, I did use a metal lathe, but, an ace on a wood lathe should be able to do it also.
1. cut out a square of the material just somewhat larger then final size-trim the four corners back to make an octagon shape.
2. using a piece of metal rod smaller in diameter then the finished size disk- place a drop of super glue on the back side of the material- center the rod on the material- a little glue will squeeze out around the rod/material- there, sprinkle baking soda. What happens, is baking soda will cause the glue to cure very rapidly. One can glue anything that way with super glue-where as the glue will not cure otherwise.
3. place the rod/material in the lathe- then using a small piece of wood or metal, with a 60degree hole-use this part to in effect hold the material against the rod using the tailstock live center. That is, the part on the rod in the lathe headstock, the tailstock live center/small piece of material sandwiching the part and holding it solid for the machine cutting forces. This is an old method that watchmakers used to make some parts. The lathe holding tool was called a shellac chuck-super glue works for me, and is quick.
4. turn the part, it should now be held solid enough for reasonable cutting.
5. remove from machine-heat the rod with a flame-the disk will fall off the rod.
Done deal!
View Loren's profile
10477 posts in 3734 days
#5 posted 03-28-2014 04:45 PM
I would just buy inlay dots on ebay rather than cut them. They
are cheap and accurately made.
Pearl is easy to chip. Generally I think the way to cut it
is by hand with a jeweler’s saw and a bird’s mouth.
BubingaBill
#6 posted 03-28-2014 05:01 PM
Unbob,
I wish I had a lathe!
Loren,
I have been looking on Ebay for the dots and I have to admit they are nice and not expensive. I just thought since I had some of this fake pearl I thought why spend the money? But I have to agree the premade ones do look perfect!
unbob
#7 posted 03-28-2014 05:25 PM
but… can one purchase the holes for the inlayed disk to fit in on ebay?
Always easier to create the hole first, then fit the peg.
For example, if a drill press is what is used to make a hole with a flat faced center cutting bit, the chuck run out even as small as .003” will created a hole that is .006” oversized. That would look bad on a 3/8” inlay.
BubingaBill
#8 posted 03-28-2014 08:20 PM
True but without a lathe I don’t have much choice now do I?
unbob
#9 posted 03-28-2014 10:00 PM
You do.
With only a drill press, the part can still be chucked and worked much the same way, perhaps abrasive paper glued to a small flat piece of wood to work the part down instead of a cutting tool.
The part can be supported on the front side using a rounded tip wood dowel held in the drill press vise- using Bees Wax as a lube. That would replace the lathe tailstock live center.
More or less the same as a lathe, except the part will be held vertical.
No drill press? the same can be done with a hand drill.
I have the feeling I wasted my time on this.
