Tails or Pins?
Forum topic by jack43 posted 03-03-2014 08:11 PM 843 views 0 times favorited 8 replies Add to Favorites Watch
View jack43's profile
jack43
5 posts in 1588 days
03-03-2014 08:11 PM
I’m building a saw till to hang on the wall. I want to use dovetail joinery for the top, bottom and sides. Do the tails go on the side or the bottom? Thanks for the help.
8 replies so far
View BinghamtonEd's profile
BinghamtonEd
2297 posts in 2338 days
#1 posted 03-03-2014 08:13 PM
The tails would usually go on the sides, as they would provide more structural rigidity against the force of gravity. (in other words, the bottom won’t fall out of the sides and the sides won’t fall out of the top due to the weight of the thing).
View bondogaposis's profile
bondogaposis
4688 posts in 2320 days
#2 posted 03-03-2014 08:20 PM
Yep, tails on the sides.
-- Bondo Gaposis
View jmos's profile
jmos
823 posts in 2338 days
#3 posted 03-03-2014 08:24 PM
Yup, tails on the sides. Otherwise the only thing holding the bottom on is the glue. Not that that can’t work, finger joints are strong and don’t have a mechanical lock; just make sure you have a lot of glue surface.
Same for drawers, tails on the sides, so the mechanical strength of the joint helps keep the drawer together when you pull.
-- John
jack43
#4 posted 03-03-2014 09:55 PM
Thanks to the 3 of you. That’s what I thought but the more I thought about it , the more unsure I got. Too much thinking.
View DrDirt's profile
DrDirt
4423 posts in 3711 days
#5 posted 03-03-2014 11:16 PM
Tails on the sides –
Picture it as “If there was no glue” and you put a can of nails inside on the bottom, would the bottom fall out?
Pins on sides – yes
Tails on sides- No
View oldnovice's profile
oldnovice
6773 posts in 3336 days
#6 posted 03-03-2014 11:55 PM
I could be contrary to those above but that would make be rather stupid!
PINS ON SIDES
BinghamtonEd
#7 posted 03-04-2014 01:43 PM
The point of the tail is to give a mechanical hold against the direction of the applied force. Since, in this case, the majority of force is downwards, what purpose does putting them on the bottom piece serve? Unless he’s constantly bumping into the plane till or abusing it, there should be very little side-to-side force.
View bigblockyeti's profile
bigblockyeti
5101 posts in 1689 days
#8 posted 03-04-2014 01:54 PM
If the pins are on the side the bottom can simply fall out without the addition of mechanical fasteners or glue. The same is true with drawers, you’re very unlike to find pins on the side of an old chest drawer, the face would have been long ago pulled off.
