Metal to plywood - Which adhesive to use?
Forum topic by JReed3 posted 03-03-2014 02:08 PM 9901 views 0 times favorited 9 replies Add to Favorites Watch
View JReed3's profile
JReed3
81 posts in 2338 days
03-03-2014 02:08 PM
I have a piece of 16 gage steel, 27”x30” that I want to permantly attach to a piece of .75 plywood. Anyone know which adesive would be best to bond the two together? I do not have any scrap pieces of steel to test with.
9 replies so far
View Earlextech's profile
Earlextech
1160 posts in 2658 days
#1 posted 03-03-2014 02:42 PM
Contact cement
View Woodendeavor's profile
Woodendeavor
276 posts in 2574 days
#2 posted 03-03-2014 03:06 PM
I would look into glue that they use on copper veneer
http://www.veneersupplies.com/products/Better-Bond-TC-20-Copper-Adhesive.html
Sheet metal should not be that different
View bigblockyeti's profile
bigblockyeti
5096 posts in 1688 days
#3 posted 03-03-2014 03:07 PM
Construction adhesive, make sure both surfaces are clean and there isn’t any greasy residue on the steel.
View oldretiredjim's profile
oldretiredjim
206 posts in 2352 days
#4 posted 03-03-2014 03:15 PM
Golf clubs are glued to shafts. There is a 2 part epoxy that is used to glue wood heads to steel shafts. Golfsmith and golfworks sell it. They also have an epoxy that is used to glue steel to graphite. I keep both around and they don’t appear to have a shelf life.
View Bogeyguy's profile
Bogeyguy
548 posts in 2035 days
#5 posted 03-03-2014 03:16 PM
Contact cement. The real stuff, not the water based.
-- Art, Pittsburgh.
View NormG's profile
NormG
5955 posts in 2971 days
#6 posted 03-03-2014 03:35 PM
I just called a friend who is an artist works in metal and wood. He advised Weldwood original contact cement. After 30 minutes is is not coming off, without a lot of effort to remove the item
-- Norman - I never never make a mistake, I just change the design.
View Planeman40's profile
Planeman40
1156 posts in 2728 days
#7 posted 03-03-2014 03:37 PM
I agree with the contact cement and construction adhesive. The metal and plywood will expand and contract at different rates, the metal due to temperature and the plywood due to moisture. Both movements will be minute, but will probably be enough to break a hard glue over time. This is why I think an adhesive that has some “give” would be a better selection.
Planeman
View mantwi's profile
mantwi
312 posts in 1863 days
#8 posted 03-03-2014 04:38 PM
Darn, I see NormG beat me to it. The answer is obvious when attaching metal to wood. Weldwood, the name says it all. I can’t believe how long I’ve waited for that question only to have someone else deliver the punchline. Drat.
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 2040 days
#9 posted 03-03-2014 04:48 PM
+1 contact cement… Also helps to scuff the back of the sheet prior to applying cement. I have used construction adhesive when gluing heavier gauges of steel, and it also works… But would be difficult for a sheet application to get troweled and smooth and such.
-- Who is John Galt?
