Tell Me, Are they saying that this can be wired to run on 220 or 440 3 phase?
Forum topic by ohtimberwolf posted 03-03-2014 12:04 AM 1208 views 0 times favorited 11 replies Add to Favorites Watch
View ohtimberwolf's profile
ohtimberwolf
813 posts in 2375 days
03-03-2014 12:04 AM
Topic tags/keywords: bidding delta 3 phase
“great for the garage, 208 – 220/440 3 phase”
Bidding is at $200
-- Just a barn cat, now gone to cat heaven.
11 replies so far
View Monte Pittman's profile
Monte Pittman
29382 posts in 2361 days
#1 posted 03-03-2014 12:29 AM
Yeah, 3 phase at either voltage. Not many homes have 3 phase power.
View unbob's profile
unbob
810 posts in 1926 days
#2 posted 03-03-2014 12:45 AM
Ya! don’t buy it.
Leave it for those that know how easy it is to run 3phase machines on single phase power. We want to keep paying low prices for those machines!
Ha, those that say 3phase is a deal breaker-you have to buy a new single phase motor-thank you very much!!
View Loren's profile
10476 posts in 3670 days
#3 posted 03-03-2014 01:40 AM
For you, you’ll need 220v 3 phase. To get that you’ll need
a 220v line and a phase converter.
3 phase motors frequently are dual voltage and changing the
voltage is just a matter of switching some wires around. There’s
usually a diagram. Baldor has a standard wire coding system and
I’ll bet that saw’s motor follows it.
View exelectrician's profile
exelectrician
2327 posts in 2450 days
#4 posted 03-03-2014 02:03 AM
A 220 V single phase input 220 V 3Ph output variable frequency drive (VFD) would also do the job with the output set to ramp up to 60Hz every time you pressed the start button. This would give the added advantage of controlled stopping, when you pressed the stop button. A few extra $$ well spent.
-- Love thy neighbour as thyself
ohtimberwolf
#5 posted 03-03-2014 02:18 AM
Thanks, I can get 220 to the place the saw would be setting but would I need to rewire the motor AND get a VFD?
larry
View REO's profile
REO
928 posts in 2097 days
#6 posted 03-03-2014 02:27 AM
actually all motors follow the same rules for numbering leads. Both single phase and three phase motors can be run on one voltage or double the voltage. not all motors are easy to change because the individual windings are not always brought out to a “customer serviceable” location. What makes a difference in voltage is whether the windings are paired in series or parallel. single phase motors are also reversible whether they say so or not. it takes a little digging and some testing to find the right leads buried in the motor but a little patience and the correct info and anyone capable of wiring a three way switch can accomplish it. it requires rewinding the motor to change from three phase to single phase though, and in many cases the architecture of the motor prevents this possibility. it is ok to run a 208 3 ph motor on 220. at 208-220 the windings are paired in parallel. for 480 they are configured in series.
exelectrician
#7 posted 03-03-2014 02:32 AM
Call Automationdirect.com and speak to a sales rep he will answer all your questions and help you get the right unit for your application, at the right price.
ohtimberwolf
#8 posted 03-03-2014 12:50 PM
Thanks guys, it gets a little confusing. I’ll see what I can find out and do so I’ll end this post. Thanks again. larry
You have been very helpful.
View crank49's profile
crank49
4032 posts in 2993 days
#9 posted 03-03-2014 03:37 PM
Ohtimberwolf, your motor is a 3 phase motor, it has to have 3 phase power.
You can get 3 phase power with a converter.
A VFD (variable frequency drive) is one type of converter you can use; it’s a small electronic box.
A rotary converter is another type of converter you could use; it looks like a motor.
And finally, a static converter would probably work, it’s a box containing mostly capacitors.
The VFD is the newest design and probably the best method
View bigblockyeti's profile
bigblockyeti
5137 posts in 1743 days
#10 posted 03-03-2014 04:19 PM
You won’t have to rewire the motor, any more than making sure you have a proper cord from the motor to the VFD, static or rotary phase converter. The VFD setup is pretty simple and can give you many acceleration, speed control and braking options, though these benefits are usually better utilized on a drill press or lathe. The static converters are the cheapest but typically only give you 2/3 the motor nameplate horse power. Rotary converters are the most expensive, but give you true 3 phase power and are usually sized for multiple machines at once.
ohtimberwolf
#11 posted 03-03-2014 05:08 PM
Thanks again all of you as you have helped me a great deal. Now to see what happens at the auction. larry
