At my wits end....
Forum topic by DevilDogNurse posted 03-02-2014 09:38 PM 1753 views 0 times favorited 11 replies Add to Favorites Watch
View DevilDogNurse's profile
DevilDogNurse
67 posts in 2776 days
03-02-2014 09:38 PM
Topic tags/keywords: drill press power tools stuck quill chuck
Ok…. I bought this Craftsman drill press off of crags list a couple of years ago. It works just fine, but it wobbles. I’m going to pick up a dial indicator to measure the wobble, but I know I need to get the chuck and spindle out.
I found the manual on line. The manual says to “Carefully tap chuck with a mallet” and the quill should fall out…. yeah, not happening. That sucker is SEIZED in there. I double checked and I did not see any retaining screws….. I knocked it as hard as I dare. I don’t want to damage it any more than it already is….
Can I get to the quill from the top, through the hole at the top of the pulleys? I’m about to try and find a shop that can do this…. Can you believe I used to be a mechanic? I can’t even do this simple job! ARGH!!!!!!
-- Marine, Nurse, Dad.
11 replies so far
View johnstoneb's profile
johnstoneb
2910 posts in 2166 days
#1 posted 03-02-2014 09:44 PM
if the shaft is hollow you may be able to out a long rod down thru and tap the chuck out. It looks like the chuck is on a morse taper it should tap out once you get something solid against it.
-- Bruce, Boise, ID
View hoosier0311's profile
hoosier0311
706 posts in 2019 days
#2 posted 03-02-2014 10:07 PM
I have a craftsman benchtop drill press as well. With mine you can go down through the shaft. I have a brass rod that is about 1/2 dia by 16 inches long. it works nice for this, down from the top, you will be surprised how easily it comes out.
-- atta boy Clarence!
DevilDogNurse
#3 posted 03-02-2014 10:09 PM
Thanks!!!! I’ll try and pick up a brass drift tomorrow
View BJODay's profile
BJODay
526 posts in 1937 days
#4 posted 03-02-2014 10:48 PM
I have the same DP. I also bought it on CL and the spindle was bent.
You have to remove the spring, (be careful), and remove the handle that lowers the spindle. Then the spindle is easily removed. I am happy with the DP now that the spindle is true.
BJ
View lepelerin's profile
lepelerin
495 posts in 2318 days
#5 posted 03-03-2014 01:59 AM
I have the same DP, mine wobbles too. I was not able to remove the chunk following the instructions from the manual.
I do not have a brass rod and cannot afford to buy one. I could use a long dowel or threaded insert I presume.
I do not know why but I do not feel very comfortable to remove the spring from the side.
Tell us how you removed it. Tx
BJODay
#6 posted 03-03-2014 02:16 AM
Slowly loosen the nut on the spring’s outer cover. When the tension on the nut is loosened the spring will unwind, (while still under the metal cover). Once the tension of the spring is released you can remove the spring cover completely. Then you will be able to remove the 3 prong handle from the other side. It’s been a while since I did it but I think the spindle will then drop straight down.
Caution: the spring is a coil spring and if you just pull off the cover it could unwind rapidly and cut your hand.
BJ
DevilDogNurse
#7 posted 03-03-2014 07:40 PM
BJOday,
Did you buy a new spindle?
I tore it apart and cleaned all the mating surfaces. It’s better, but not right. I still need to get a dial indicator…..
Bill
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3579 days
#8 posted 03-03-2014 08:17 PM
Get yourself a cheap dril press drift. They work great simply an angled wedge of metal with a slot sometimes you use two opposed to each other but most times one is enough.If it is a morse taper which it almost certainly will be it should come out with a little light persuasion.definitely not a great deal of whacking it which will cause definite damage.Look up drill drift on google.Alistair
BJODay
#9 posted 03-04-2014 01:19 AM
I purchased a new spindle from Sears. It cost about $50. It was delivered quickly and fit perfectly. No more wobble.
I did break the on/off switch when installing, (My own fault). They had that in stock too.
BJ
View bigblockyeti's profile
bigblockyeti
5111 posts in 1714 days
#10 posted 03-04-2014 01:37 AM
Your chuck is almost certainly pressed onto a Jacobs taper, one of the best ways to get it off is to chuck up a router bit and try using the DP as an over arm router. I’ve fixed five that had the chuck come off while trying this. The spindle is one piece that fits into the quill. If you can drop the quill out by just removing the spring, you can then press the spindle from the quill, flip it and press the spindle from the chuck with a drift or something thin enough to fit through the hole in the bottom of the chuck.
DevilDogNurse
#11 posted 03-04-2014 04:22 PM
OK…. I thought I would share how this thing got blown apart and put back together…..
First, using my $5 Harbor Freight Deadblow, whack the Chuck to remove it!
Then, Loosen the retaining nuts on the crank shaft return spring
Nuts Removed
Here is the return spring, cover and backing plate
The assembly containing the hollow crank and the spindle will fall out once you remove the actual crank arm (Forgot to get a pic of this…... OOOPS)
Remove the C-Clip ring from the spindle shaft so you can remove it from the hollow crank…. try not to break it like I did
As you can see, this is NOT a morse taper! The spindle rides in two sealed bearings which in turn ride inside the hollow crank body.
I’m going to splurge and spend $30 on a dial indicator at HarborFreight. Evidently they are decent enough quality. I should be able to measure the runout on the spindle shaft itself. I don’t have a “calibrated rod” to put into the chuck, but This should tell me if the shaft itself is bent and how bad.
I ended up putting everything back together after cleaning it really well with WD-40. Its much smoother and the wobble is no where near as noticeable. But its not perfect and that will drive me bonkers.
