best glue to use for laminating hardboard to plywood?
Forum topic by knotheadswoodshed posted 03-02-2014 03:15 PM 9726 views 0 times favorited 5 replies Add to Favorites Watch
View knotheadswoodshed's profile
knotheadswoodshed
212 posts in 2075 days
03-02-2014 03:15 PM
Topic tags/keywords: jig question
Hi All,
I am in the process of making a new drill press table.
I have a core of 3/4” baltic birch and plan on putting 1/4” tempered (smooth both sides) hardboard top and bottom.
I was thinking contact cement but am wondering if there are better options?
Thanks
Randy
-- Randy - "I dont make mistakes, I make design change opportunities" www.knotheadswoodshed.com
5 replies so far
View gfadvm's profile
gfadvm
14940 posts in 2593 days
#1 posted 03-02-2014 04:36 PM
Your contact cement will work fine as will Titebond Wood Glue. I would lightly sand the hardboard if using wood glue.
View cajunpen's profile
cajunpen
14575 posts in 3969 days
#2 posted 03-02-2014 04:49 PM
I think that either would work fine – as gfadvm said I would also sand the underside of the hardboard as well as the upper side of the plywood. Also another consideration, since it’s a drill press table I would consider just using some 3/4” nails to secure the two surfaces – as long as the are countersunk I can’t see any problem that they would cause – of course I would stay clear of the immediate area where the drill bit might go through (the center of the table area).
View bluplanet's profile
bluplanet
37 posts in 2565 days
#3 posted 03-03-2014 07:32 AM
Are you familiar with MDO? (Medium Density Overlay)
Its a plywood that sign painters use. It has a hard kraft surface over a rigid plywood and can be one sided or double sided. It comes in 1/2” and 3/4”.
Its every bit as smooth and hard as the tempered hardboard you want to use and is probably easier to replace with another piece when the time comes since you don’t have to do any lamination .
Not every place stocks it. You might have to call a few places.
View NiteWalker's profile
NiteWalker
2736 posts in 2480 days
#4 posted 03-03-2014 12:22 PM
Regular wood glue will work fine.
Contact cement will too, with the added advantage of being ready for use instantly.
Just make sure to rub it down really good so you get a good bond and a flat, even surface.
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 1975 days
#5 posted 03-03-2014 10:53 PM
I have had the moisture in wood glues bubble up hard board. I always use weldwood contact cement.
-- Who is John Galt?
