How Do I Repair a Frost Proof Water Faucet/Pump?
« back to Hand Tools forum
Forum topic by yag113 posted 03-02-2014 01:14 PM 1294 views 0 times favorited 10 replies Add to Favorites Watch
View yag113's profile
yag113
28 posts in 1665 days
03-02-2014 01:14 PM
I have a freeze proof water pump in the yard, the type that goes a couple feet in the ground with the handle on the top that you pull up for water. I stupidly left the hose attached and the handle in the up position and it froze. When it started thawing a fine mist of water started spraying from what appears to be a seam on the bottom side of the metal near the spout. Is there anyway to repair this or should I just replace the whole thing?
-- Shore Wildlife Rehab
10 replies so far
View JustplaneJeff's profile
JustplaneJeff
263 posts in 1901 days
#1 posted 03-02-2014 01:44 PM
Time to replace it my friend. When you do, make sure you put plenty of gravel in the bottom of the hole to allow it to drain, and remember to un-hook the hose lol
-- JustplaneJeff
View bondogaposis's profile
bondogaposis
4727 posts in 2349 days
#2 posted 03-02-2014 01:48 PM
Is the pipe split or is there a crack in the casting? Here’s a video on how to replace the washer, it will give you an idea of what you are in for. Probably replacement of the entire unit is going to be the best solution.
-- Bondo Gaposis
View JoeinGa's profile
JoeinGa
7736 posts in 2005 days
#3 posted 03-02-2014 02:18 PM
Several years ago I had to replace the one I had in Tennessee. If I remember correctly they are only about $35 or $40 at the big box stores.
Mine crapped out because who ever installed it didn’t have enough gravel under it to drain properly.
View mahdee's profile
mahdee
3883 posts in 1765 days
#4 posted 03-02-2014 03:23 PM
The hardest part of replacing one is digging the hole. I used sand instead of gravel. I don’t think its a pump, just an outdoor faucet. Main thing is to be careful not to move the pipe too much or it will break the PVC main pipe it is attached to. Be sure to turn off the main coming to the property.
-- earthartandfoods.com
View gfadvm's profile
gfadvm
14940 posts in 2688 days
#5 posted 03-02-2014 04:35 PM
In my experience it is quicker and easier to replace than to repair. Dig it up, unscrew the old one , and screw in the new one. Being careful not to break the main PVC line.
yag113
#6 posted 03-02-2014 11:45 PM
Definite theme to the replies! Replace it! Just what I thought but
WTF do I know about this sort of thing…. I repair wildlife, not
Leaky faucets.
Did u ever see the movie “Mr Blandings Builds His Dreamhouse?
Carey grant buys a house in the country that “needs work” &
Calls in multiple contractors who unanimously say “tear it down”.
Message received…. And yes, it’s not the cost… It’s digging the
Hole. Oh well, like they say, sometimes u eat the bear &
Sometimes the bear eats you! Thanks guys! Knew you would
Weigh in!
GF/shore wildlife rehab
View swoper's profile
swoper
59 posts in 3222 days
#7 posted 03-03-2014 12:06 AM
I feel your pain, I have to replace/ repair the one in my barn. I think my connection from well pipe to faucet is what failed might be a stainless screw clamp.
-- Harry, Jackson Mi
mahdee
#8 posted 03-03-2014 12:53 AM
yag113, WTF do I know about this sort of thing….
If you don’t know about these things on Wed, Thur and Fridays(WTF), try Mon, Tue, Sat and Sun. Just kidding. Yea, WTF. It sucks when things go wrong.
View Grandpa's profile
Grandpa
3259 posts in 2673 days
#9 posted 03-03-2014 02:14 AM
I read then reread your post. When it started thawing then spraying was the hose still on the faucet? The valve is in the bottom of the system and the pipe should have been empty unless you leave the hose on it and it can’t empty. My question is, was your valve properly adjusted to let it drain back or did it hold water in the pipe all the time? If it held water all the time and was not properly adjusted you need to make sure this doesn’t happen again. Adjust your valve so it can drain. You can adjust these where they don’t drain but they do shut the water off. I have several of these and have used this type faucet for about 35 years. I found that the batter faucets come from the plumbing supply stores. The ones from Tractor supply and Atwood’s were not the same quality.
yag113
#10 posted 03-03-2014 12:41 PM
Good to know! I’m headed for Tractor Supply today for some animal feed… and was going to check out a replacement. But I’ll check my local plumbing store. It’s always something, isn’t it!
To answer grandpa, the hose was still on AND I had left the handle up. It seemed to be a leak in the casting?
Just heard Minnesota has had 50 sub zero nights this year! Glad I’m in Virginia. Stay warm and my advice, make sure you put the handles down on your frost free faucets!
